With the USB-C charging and dual switches, this is an interesting light for sure.
I would like to see some side by side comparison photos of this and older baton models. How much bigger this looks like, and how wide the beam is compared to other baton lights. This seems like it might have a bit tighter beam, which would make it not so good for close range illumination.
Yes they did it again, SST40 in 2026β¦
Itβs the same size as the Warrior Mini 3 (111mm x 23mm), a little under 10mm longer than the Baton 3 Pro due to the tail switch and USB port. Still a reasonably compact light.
