In the event that you would like to melt your forehead off in a matter of ~30 seconds.
I would assume way over exaggerated.
Edit: Appears he accidentally posted the Fenix LD50 flashlight’s specs. Here is what is listed at the product link page for the Olight H25 Wave:
Features:
Three Brightness Levels
Manual Switch or Infrared Sensor Activation
High Performance CREE XM-L2 Neutral White LED
212 Meter Maximum Beam Distance
Light Head Tilts 55 Degrees to Adjust Beam Angle
Includes Rechargeable Lithium Battery Pack With USB Charging Port
Battery Pack Can Be Used To Power USB Mobile Devices
IPX 6 Water Resistant
Working Temperature: –20 to 40 Degrees Celsius
Specifications:
Light Source: 1x CREE XM-L2 Neutral White LED
Runs On: Rechargeable 7.4V 5200 mAh Li-Ion Battery Pack (Included)
Output Mode / Runtime:
High: 800 Lumens / 5 Hours
Medium: 250 Lumens / 12 Hours
Low: 35 Lumens / 60 Hours
Dimensions:
Headlamp: 62 x 42 x 29mm
Battery Pack: 97 x 85 x 30mm
Weight: 123g (Headlamp) 320g (Battery Pack)
Package includes (with original box packaging):
Headlight x1
Head Band x2
5200mAh 7.4V Battery Pack x1
AC Charger x1
Power Cord x1
User Manual x1
