This was my t-day project. This is a S10 I designed a 7135 driver for using DrJoned RGB FW. It's runnong XP-E2's right now but the project is actually based around a Lime, red-orange and blue rebel on a triple sinkpad (which I'll get later), that's why I only made it 2x 7135 each. This is also the first double stack driver I've ever done.
link to DrJones FW description. Note I'm using the specially modified RGB only FW, DrJones replaced the white channel with R,G and B at even levels in the code so there is no holes in the UI. a hold (which would bring on white on the normal FW) brings on an even mix of RGB that's brightness rampable.
The triple conversion was a lot of work on its own, as was the driver and getting the switch positioned correctly.
top/bottom of each board (mouseover)
stacked
even with all the RGB work I've done this was my first time wiring a noctigon individually addressable, remember this is temporary (till after xmas shopping season), rebel's to come
looks factory right
Eh, I dont thing thats factory!
(mouseover = on "white")
