S10R ebay link
amazon S10R like
The S10R Baton is an extremely small, powerful, and rechargeable 400-lumens LED flashlight with an intelligent multi- function side switch. There are a total of four different power settings and a strobe mode. Its small size, high output, four brightness levels, and strobe mode make it the perfect all-purpose light. Barely larger than the single RCR123A battery powering it, the tiny S10R disappears into a pocket or your palm. You can comfortably carry it all day long at the offi ce or on a camping trip. And with its included rechargeable lithium-ion battery and compact Micro-USB charging dock, you don’t have to worry about bulky chargers or special cables. The S10R also features a power indicator located around the side switch, which will glow red when your battery power is low. With it’s dual purpose magnetic tailcap, you can use the S10R as a hands-free convenient worklight, and attach it securely to the included charging base. Never be without a powerful light — the S10R Baton is the perfect constant companion.
NEW Low-profi le side switch featuring a battery power indicator, which glows red when battery runs low
• NEW Includes patent-pending Micro-USB charging dock and a 650mAh RCR123A rechargeable battery
• NEW Thermal management saftey program provides overheating protection by dropping high output by 50% after 4.5 minutes of constant on.
• NEW Glow-in-the-dark o-ring in bezel to help locate fl ashlight from accidentally dropping it
• 99% light transmittance rate through tempered glass, with two-sided anti-refl ective coating
• Multi-function side switch with four brightness levels, plus a strobe mode
• Automatically return to your last brightness level with the built in memory function
• Removable two-position pocket clip
• Flat tailcap with strong magnet, giving you the ability to use the light as a hands-free worklight
• Highly reliable 6061-T6 aluminum alloy structure with ant-scratch, Type-III hard anodizing with a stainless steel bezel to protect against drops
• Enhanced shockproofi ng in battery contact springs to support both fl at and tabular 18650 batteries
• Reverse polarity protection to prevent improper battery installation
• Can be powered by one non-rechargeable CR123A lithium battery as a last resort in an emergency. • Low standby current below 15uA
