Just received 4 pcs of Liitokala 26650 yesterday. Voltage around 3.82 V.
I will do capacity tests on 2 of them in the next days. Tests will be on 1A, 3A and 5A. 7A test is possible on request.
Nice to know; mostly interested in the 5+A figures and, please, would you mind mentioning both initial no-load voltage and the subsequent initial load voltage? This would be to comfirm the pretty good IR figures initial testers are reporting.
Here are my test results on two of my my LiitoKala 26650 batteries:
To understand these results you have to keep in mind that I did not “condition cycle” the battery before doing the test. So the 1A test was the first discharge on this battery ever. 2A the second and so on.
Obviously the battery gains capacity within the first few cycles.
I charged with 1.5A. Cut off voltage while charging was pretty much exactly 4.2V at 0.15A.
Discharge started at 4.185V
Discharge cut off voltage was 2.80V.
No 1:
1A: 5043 mAh
3A: 4972 mAh
5A: 4990 mAh
7A: 4953 mAh
No 2:
1A: 5092 mAh
3A: 4986 mAh
5A: 4981 mAh
7A: 4961 mAh
The batteries match nicely.
I am sure the other pair will have the same results, so I am not doing tests on them.
On 5A the battery barely warmed up. On 7A it warmed up but did not get hot.
This seems to me as a pretty good result so far.
The weight of the batteries:
95.2 g
95.6 g
96.1 g
95.8 g
Notice: None of my LiitoKala 26650 will work in series as the flat top is too flat to give contact.
Good figures
I am surprised that your cells don”t work in series though.
On first inspection I didn”t expect either of my pairs to work in series as the tops are very flat but I have tried both pairs in my S70 & they work fine in series ?
Yes both pairs of mine run fine in series in a light
I expected to have to add a magnet to 1 positive to run them in series but didn”t have to.
My 4 cells are well matched in terms of IR, capacity & weight.
They did not get warm when run in a light drawing about 5.5A, my heaviest draw light, so are fine for my needs.
This battery not made by LiitoKala .It is by an unknow China manufacturer.
This battery is true 5000mAh ,And even more than 5000mAh .One question is the battery diameter is about 26.5mm .A little bit big than 26mm. The Battery internal resistance is about 13-15mΩ.
About the discharge ability. This battery can be discharge at 20A.However, it was recommended work under 15A .What’s more ,The battery it CID(current interrupt device).The CID will work when battery work about 30A .And it means battery die and no recovery.
A bit of a pity because 26650 users could have enjoyed them much earlier, but alas, people tested Soshines yet they left the best of 'em behind and forgotten.
Of course, now we can get the LiitoKalas even cheaper, but it took us to see some sort of reputable brand name on the sticker to risk our pennies.
I just contact with the store owner .
The guys told that he know who made this battery and do not want to give the name
His answer is : The battery not made by BAK ,But with relation with BAK . It made by a company whoes boss evry been the engineer of BAK
sidecross, I bet you the LiitoKala logo/markings are also computer generated, then sent to whatever offset or any other appropiate industrial printing machine to make the “retail adjustment” on the wrapper. Or did you succintly tried to mean the photos are computer manipulated? I doubt so. FastTech has been stocking that product for nearly a year now, they tested them and they've sold some. :-)
So, a startup company founded by some kind of brave & talented engineer who decided to build a 26650 battery which starts to make justice to the volumetric possibilities of the format. :THUMBS-UP:
