Hi everyone !
I searched the first 3 sites of the CR123 section here on BLF, to find my future almost-EDC flashlight.
I want to start with the specs I’m looking for:
- runs on single CR123 primary
- good overall built quality (this includes that it will last longer than just a few months)
- clicky switch
- maximum lenght of 3,1 inches / 8cm
- $30 should be the limit
- no strobe modes, hidden modes should be fine
I will write down a short list of flashlights I found so far and what I like and dislike about them.
- Eastward YJ J08 - http://www.dealextreme.com/p/eastward-yj-j08-cree-xp-g-r5-3-mode-260-lumen-memory-led-flashlight-with-clip-1-cr123a-1-16340-44961
pros: size and prize
cons: build quality seems to be lousy, if you read the dx-forum and a few ratings there is the possibility that it dies within a few month, strobe but no low-mode
- LumaPower Incendio V3 - sorry no link available
pros: size, powerful little flashlight, overall build quality, no strobe modes
cons: price, unnecessary things in the package (tweezers? who needs them, this increases the price of course)
- Nitecore EX10 - Review: Nitecore EX10
pros: build quality, size, strobe modes are hidden
cons: price, small parasitic drain
I will not mention the EX11 because it’s even more expensive.
- Ultrafire RL-113 - Review: Ultrafire Stainless Steel RL-113
cons: stainless steel and because of that a flashy look —> that’s a big con
- ShiningBeam I-mini value edition - http://www.shiningbeam.com/servlet/the-83/ShiningBeam-I-dsh-mini-Value-Edition/Detail
pros: price (BLF discount available)
cons: size (8,6cm), parasitic drain ?, UI —> loose head to start ramping
- ShiningBeam C-mini - http://www.shiningbeam.com/servlet/the-22/SD-Reader-MicroSD/Detail
pros: price (BLF discount)
cons: UI is combination of clicky and twisty and there is a strobe mode, size (8,6cm)
A few more intel:
- I got no problem with the use of 16340 (aint got a charger yet), you can suggest lights that run on both CR123 primary and 16340.
- I know that twistys are usally shorter, but I wanna try a small clicky now (already own an ITP A4 EOS 2xCR123 with twisty)
- There’s no need for a XM-L, I will be fine with XP-G, XP-E and so on.
- The EX 10 seems to be the one closest to my specs, but I can’t afford it, same goes for the LumaPower.
(Maybe I should consider the purchase of a used EX10?)
Thank you for reading this ! ! !
Which flashlight would you consider to buy (which is not on my list already) ?
I promise I will listen to every single hind of you and do my researches.
kind regards
