Remove tailcap from the Rook. It is thread locked with some red epoxy.
Remove the contact board form the battery tube. This gives you a clean shot of the contact board and exactly where the batteries touch when fully engaged.
Taking a Sharpie, because a pencil doesn't leave easily seen marks on the contact board, stick it into the battery tube and trace out the contact areas on the contact board.
It will look something like this...
Take off the battery tube and your contact areas are clearly marked and perfectly centered.
With the contact areas clearly marked, we can apply some nail polish to the contact board onto the areas where the cells don't make contact when the tube is fully tightened. Prior to coating the areas, you may want to scratch up the surface with a dremel stone (held in your fingers, not using the rotary tool) or small file so that the nail polish has more to stick to. Follow up by cleaning the surface with alcohol and a Q-tip. Not doing so can allow the paint to come off easily. Your end result should look like this:
I used an IR light to help accelerate the hardening of the nail polish. I used white polish for 2 reasons. First is because unlike clear polish, I will be able to see if it chips or wears away with use. The second reason is I already had it from filling the engraving on my handgun.
Once fully dried and cured, reassemble your Rook and enjoy your non-parasitic draining torch! A 60 degree twist will fully and securely lockout parasitic drain from the electronically switch driver. Special Thanks to "The Last Katun" for the incredibly simple idea that inspired this. Truly brilliant, he is! Saved me a ton of hassle form doing an OL style tailcap lockout mod. :beer:
EDIT: If the nail polish comes off (and I have a feeling it will, even with the roughed surface prep) I will repeat with a thin layer of epoxy instead of the polish. It should work far better.
Tried to follow the OP idea, it was harder than it looked..trying for 20 minutes without satisfaction.
Then the thought just came out, instead covering the whole board and make an opening for battery connection, it's easier to just cover a small area which the battery should not contact.
I using thin clear tape. The thinner yet stronger adhesive is better.
Here it is, just like the OP idea and perhaps most quick in applying :D
Yep. I think we’re all going with the idea of just covering the small area which the battery should not contact.
The OP’s method works okay, but it’s more fiddly when trying to figure out where the battery will contact — just not convenient if you need to the flashlight from lock out mode.
I’ll have to try and find some thin tape (any recommendation where to find) and give it a try. You got some nice cutting work on your tape. I’m going to wait and see if/when my nail polish comes off - so far it’s holding up.
Just received this light today. Any recommendations for removing the tail cap on this? I tried with my hands at first and then even tried a rubber jar opener. No go Strap wrench? I’ll have to buy one or 2 I guess from Harbor Freight.
You could try what they do to get a TN31 head apart. Seal the body in a plastic bag and then put it in boiling water for a couple minutes. It's worked for me on my TN31. It was still hard to break loose. Strap wretches kept slipping. So I just used leather gloves and a whole lot of grunting.
Wonder if this would work on lights in the same genre such as the EA4 and others? Even though they have lockout features, this might do away with the small parasitic drain they do have.
