Opple Light Master 4 discussion thread (new 2023 model)
FWIW, wrt Duv in these low cost devices, for me, a reasonably good match between 2 devices is about 10-15 points, and a great match is about 0-10 points.
For example -0.0020 versus -0.0030, a 10 point difference, is a good match between the 2 devices being compared. 0.0020 to 0.0035 is a 15 point difference, still ok, but starting to get out of range. Just IMvHO and YMMV.
I try to determine a trend for my Opple LM3 versus typical known numbers for any LED. My LM3 has been doing a decent job: for example big negative numbers for Nichia 219 4500k, and positive number for LED’s with green tint. LM4 has failed, seemingly/mostly with high CCT low CRI lights.
agree, on the 4 Low CRI lights, LM4 reports about 0.0040 lower DUV, and is unable to measure R9.
On high CRI lights the LM4 mostly reads R9 about 5 points higher than the Xrite. But the most glaring discrepancy is for the LM4 reporting R9 20 points higher than the Xrite.
Here are my measurements with 6 different LEDs… Most are high CRI.
LM3 = Light Master 3
LM4 = Light Master 4
Spectro = Asensetek Lighting Passport Standard Pro
I measured the lights inside a homemade integrating sphere. I noticed that this gets the most stable measurements, instead of pointing a light directly at the sensor.
I did 1 measurement per device, and sometimes 2, if I wasn’t sure that I held it straight enough.
Solarforce L2i Nichia 119A warm CCT DUV CRI Ra R9
LM3 2696 0.0004 85.7
LM4 2686 0.0001 87.3 27.6
Spectro 2695 0.0001 89 59
Convoy S2+ Nichia 219B 4500K CCT DUV CRI Ra R9
LM3 4237 0.0020 93.9
LM4 4173 0.0038 92.9 93.6
Spectro 4177 0.0015 94 88
Emisar D1 (FC40 5000-5500K) CCT DUV CRI Ra R9
LM3 5041 -0.0003 97.6 -
LM4 4957 0.0021 94.5 77.5
Spectro 4972 -0.0005 95 71
Convoy S2+ Nichia 519A 5700K CCT DUV CRI Ra R9
LM3 5091 0.0058 97.6
LM4 4997 0.0080 93.1 100
Spectro 4976 0.0052 92 85
Vosteed Rook (CREE XPL) CCT DUV CRI Ra R9
LM3 5206 0.0060 68.4
LM4 5270 0.0036 63.3 51.3
Spectro 5401 0.0077 71 -11
Olight Baton S2R (cool white) CCT DUV CRI Ra R9
LM3 5410 0.0092 63.9
LM4 5550 0.0075 62 37
Spectro 5622 0.0118 67 -28
There is no real conclusion to get from this. Just that sometimes the LM3 is closer to the Spectrometer, and sometimes the LM4.
The R9 in cool white, seems to be difficult for the LM4 .
8 Thanks
Today, the weather was nice, so I decided to take some measurements of natural light with my LM4.
Here are two measurements I took in the shade: one pointing towards the clear sky and the other pointing towards the ground.
Something is clearly wrong with R7 and R12. R4, R8, and R11 are well below 100.
I still find my LM4 useful, but some numbers displayed here may be bogus.
Thanks for the data :wink:
fwiw, in every example of DUV, the LM3 is closer to the Spectrometer, than the LM4.
For High CRI LEDs, the LM4 reads DUV between 0.0018 to 0.0028 too High, and the LM3 is closer to the Spectro.
otoh, on the Low CRI LEDs the LM4 reads DUV between 0.0041 and 0.0043 too LOW, and again the LM3 is closer to the Spectro.
agree, the LM4 is very inaccurate for R9, when testing Low CRI. The LM4 is also very inaccurate for DUV, when testing Low CRI.
In all 6 tests of DUV, the LM3 is more accurate than the LM4.
otoh, the LM4 calculates the DUV automatically, which is very convenient, if only it was as accurate as the LM3. For the LM3 I have to go to the waveform site to calculate the DUV from XY coordinates, which takes extra effort.
I was hoping Opple would give us duv calculation and maybe a higher resolution CIE diagram in an update for the LM3, but with the LM4 using a different app now, that chance seems pretty low.
How can I use the DUV values to calculate the color shift in a DSLR?
eos-80d-menu_1325-2
@jon_slider
My pleasure…
@xseven I wouldn’t even think of that.
Or are you going to do product photography in a stable environment, with the same lighting conditions all the time?
Not swapping lenses?
I would recommend shooting RAW, and do the rest in post processing.
Great question!
I know only a little about that level of photography. Normally there are reference color sheets and a standard gray sphere correct?
Using something like the LM3 X and Y values seems like it could work to color correct photos in post processing, at least to get pretty close.
You could buy some reference colors and start shooting.
Making series of measurements with ML4 and colormunki I see that only LM4 value can be trusted is CCT (for LED ).
However CCT measurements is not very strict in both ML3/4 so Duv can’t be trusted. Duv=0.001 is equivalent of 50К for 3000K. Difference between LM4 and colormunki CCT sometimes is more than 100K. Thus Duv could only show if light is very green or very rose.
Ra and Ri from LM4 is a mess.
Ra by definition is mean R1-R8 . I cant find any LM4 measurements where it is true. Thus calculations(application work) of Ra or Ri (or both) are wrong. Bigest difference between ML4 and colormunki that exists in almost every measurement is in R7, R9, R12. But for almost all Ri can be found a source with |Ri(lm4)-Ri(xrite)|>15.
I asked Opple on AE about wrong Ra calculations but still no answer .
For photos … Sure!
But for video … sometimes in mixed light situation the camera is not very accurate in Auto WB … so I was thinking I could get some help from the LM4
Hi guys! I’m kinda new here. Also I’m a ligting designer based in Brazil, so sorry for the rusty english.
I’ve been thinking about buying the LM4 for daily light measurements, so I was wondering if anyone here have tested it with “normal” lighting, even though the forum is focused on flahslights, etc. I don’t know if thar error could appear only on super high lux levels, as I’ve seen been tested here.
Thanks btw! :slight_smile:
the errors are there at low lux also…
but maybe you will enjoy using the Opple 4 anyway, even though it is not very accurate, it may be useful…
here is an example of how Opple 4 and Opple 3 read my house lighting:
in that example the differences are not very large, because my house lights are High CRI, a mix of 2700K and 3000K LED bulbs…
Where the Opple 4 has the largest errors, is with duv and R9 on Low CRI lights… It does not matter if the test is at high Lux or low Lux…
I tested some regular lights in a home
LM4 measured a slightly higher CCT than expected for a cool white light and duv was different.
My LM3 got here today (because it was cheap, so why not) so if I get some time this weekend I’ll try and take some comparison shots with both. Still have the last stack of beamshots I did that I haven’t got round to sorting or testing (my life the last week or two has just been constant thisisfine.gif…), but I think my technique was a bit flawed on those so probably just going to give it another go if I find the time.
Measurements are almost constant for the same sourse during increasing lux from 1 to about 25000.
although we are kind of in dilemma, but we are trying to fix it.
You’re working for Opple? Care to elaborate a bit about that dilemma?
Welcome to BLF!
:eyes:
