More Opple data
testing stock lens of FWAA impact on DUV (it has a pink AR)
FWAA with uncoated sapphire lens
3x 3500k 219B
DUV –0.0005
with original fwaa lens in front
DUV –0.0001
net change, not significant… +0.0004
First, I measure in the dark, with the light that has an uncoated sapphire lens, 6” from the sensor…
next without moving the light, I place the test lens against the bezel and take another reading…
it seems the absolute values may not be the same as on a more expensive and calibrated instrument
however, I think the comparison of the same light, with and without an AR lens, might be giving useful data… for me to compare with my own light and lenses
I do also use the Opple to test LED light bulbs in my house, for flicker, and DUV
and also to compare the DUV effect of blending two beams…
and it also lets me compare the DUV of different LEDs
I have several different sw45k for example, and some are much more pink than others
the Opple DUV calculation tracks what I see with my eyes… the most pink has the lowest DUV
when comparing multiple lights, first I start by setting them to the same lumen output, on a separate meter. Then using the opple I set the light distance to produce similar lux on the opple,
and then I use the xy coordinates to calculate DUV online
