1. It seems to not recognise non-rechargeable AA batteries. It will attempt to charge them.
2. You can charge NiMH batteries at 1000mA! Mix some Li ions with the NiMHs and keep pressing “Slot” until all active channels are flashing. You can then set all active channels to charge at 1000mA, including the NiMH. I did not let the charging continue as I am afraid of killing my NiMH or causing then to explode.
If you don’t want to unscrew the bottom, just Dremel out a football shape hole over top of the switch location and vacuum out the plastic bits.
Easy enough to get to the switch with small toothpick/screwdriver etc.
I’m thinking of buying this charger, any idea how long it would take for this charger to get to California from Gearbest (it says: Ships within 3-5 business days) and is there any discount codes available?
I am still waiting for mine from around the start of April. The typical “up to 25 BUSINESS days” response when I inquired where it was. I did not even get any confirmation email until I asked them what the order number was…. then they had all that information suddenly… I think it shipped the 7th of April according to them…
I am looking forward to it, but am finding GearBest to be slower than Banggood or Fasttech by a wide margin, so I am avoiding ordering from them if I can…
does it have a battery storage charge mode ? where it charges to optimal voltage for storage ?
anyone who have moded it to quickly select 4.2 or 4.3 volt batteries with minimum surgery ?
however i had charged samsung icr -30a extracted from laptop to 4.3 volts using my diy lm317t liion charger circuit .. and tested in opus ..it didtn complaind that the cell is 4.35 volts and happliy performed the discharged test .. i got 300mah more capacity when it ws charged to 4.3 volts compared to 4.2 volts.
I cut a small piece of plastic out of the bottom. The switch is right there, maybe a half inch away or less. Mine is a version 2.1. I’ve been using it a lot, never had a fan issue or any issue for that matter. Very nice unit!! I could make use of a second one, if I can find us a code I’ll share it here.
