I bought a new opus BT C3400 and I was wondering what people thought about since its release. I got to maintain all of my rechargeable batteries.
It has been out for a while now and most information that I find, is related to initial reviews. So I wanted to know if there is any new developments that I should be aware of or any tips.
The BT-3400s were made for rdana on EBay and were slightly upgraded 3100s.
For starters, the 3400 v. 2.2 has a 2.80v cutoff for li-ions, a better fan and the ability to toggle off the display.
Earlier adopters, like me, complained that 2.80v was a bit low for their comfort levels, so v. 3.1 was released, which bumped the li-ion discharge level up to 3.10v.
I have both versions and use them often.
If you Google it, you’ll see that you can remove the bottom cover and drill a hole over a slider switch that will allow you to charge all three common li-ion voltages.
I have the V3.10 and so far I like it. I was able to do a charge test with 4, 18650 batteries at the same time,which I can’t do with my liitokala lii-m4s.
Thanks, that is good to know. So far I have been impressed with it. However I did a charge test and when it’s done it’s supposed to flash “full” but it’s not doing that. Is this something that I should be concerned about or return it for another one?
