I have had my 3400 upgrade version for a couple of weeks and when I charge anything under 3.7v it never says when it’s finished by flashing full.
I even exchanged it for another one and it does the same thing.
I charged a EBL 1.2v 2500mAh next to a 3.7V 14500 1000mAh battery and it flashed the full sign when it was done but after the EBL got to 2000mAh I waited 2 more hours and the charge number never changed and it never flashed full.
#1 I have had lots of issues with EBL batteries – just the other day in a small 4 slot charger, 3 batteries charged in a couple of hours-- the fourth never did finish
Also with NiMh make sure you charge at a high enough amperage – 2500mah-- at least 1000ma
I have been charging at 500mA. I will switch to the 1000mA and see what it does. All of the 2500mAh batteries are staying under 2000mAh but the EBL 1100mAh batteries are coming in at 95%-100% of the 1100mAh claim.
Most chargers wouldn’t know when a AA NiMH is fully charged if only 500ma is used. You should have more luck with 1000.
Also, most chargers wouldn’t know when a mostly charged NiMH battery is fully charged. Like if you’re topping them off. So discharge them somewhat before charging. At least partly.
That’s about right for most Chinese batteries – most of the time between 2000- 2300 mah
I really don’t like the way the Opus does the capacity test for NiMh – My MAHA 9000 charges to full lets the batteries rest 2 hrs – then it does a full discharge — then another 1 hrs rest before fully charging back up
you can do this manually with the Opus, but it’s a pain in the butt
Charge to full at at least half of the rated capacity ( I think Opus maxes at 1000ma NiMh)
let them rest
Do a full Discharge cycle
let rest
Do a full Charge cycle
Do you want speed, or accuracy and the best handling of your cells for performance and longevity?
I personally will go for the latter. Besides, there is no hurry when I am doing capacity tests. Set it up and walk away.
When it is done, well, it is done.
Not sure which chargers are really accurate, I always have differences if I test with different chargers. Sometimes it depends also on the slots.
For me it´s more a test to see if the cells are somewhere in the expected range or far away.
Cheaps cells like Bonai, Powerowl are mostly far away from the rated capacity, for AA 2800 it´s more 2000-2200mAh, similar to some Discounter-brands, 2500mAh rated is mostly also 2000-2200mAh.
And yes, if you charge and immediately discharge you will have different results than let the cells rest after charge.
The highest accuracy would be test it all with same conditions.
