Heya folks, is it possible to get alternative (oragne peel) reflector for my Wurkkos FC12, I would like to have something with less pronouced difference between hotspot and spill.
Sized as on pictures bellow.
You could try d-c-fix instead.
Do you have an old Convoy S2 around? Those had deeper reflectors than the S2+. Will the straight diameter work in the host or does it need that small reduction on the lower half?
I think KD’s measurements are probably more accurate but here are the listings from both Simon and KD:
https://www.aliexpress.us/item/2251832637297364.html
http://kaidomain.com/Flashlight-DIY-and-Tools/Reflectors/S027395-20mm-x-19mm-OP-Aluminum-Reflector
