Oring material
Any suggestions for the longest lasting o-ring material in a flashlight application? I’m not as worried about wearing the o rings out on my less frequently used lights but I would like to maintain their performance over time. Most of my critical duty lights see very little use and in all honesty probably won’t get updated until there is a SIGNIFICANT breakthrough in lighting at this point.
Would nitrile or silicone offer better longevity? I don’t mind changing what I use for a lubricant if necessary (right now I use silicone grease on some and nyogel on others).
Personally I like silicone o-rings when used with the correct lube for them.
With nitrile rings you can use silicone grease as a water repelling lube.
With silicone rings, every lube swells or eats the silicone over time. Especially silicone grease will swell silicone rings and turn them into a sticky goo over time. This could be intentional, if it will not be opened frequently, as it will need replacement as soon as a a slightest moment of friction is applied to the goo. This includes pressure (diving/high altitude/space), which will then break the viscous gooey seal very easily, especially at low temperatures. The goo can easily glue everything together, making unscrewing the flashlight almost impossible.
Have anyone tried teflon orings?
Not at all. With nitrile oring yo can use silicon grease or PAO grease.
With silicone o-ring yuo can use a wide list of greases, except silicone grease.
And we should understand, that a lot of greases that called silicone is not on silicone base oil, but thickened by pyrogen silicium, that’s not the same. Such greases are safe for silicone o-rings, and, if based on PAO base oil - for nitrile.
Interesting. So ideally would. Viton. Not that you can find flashlight sided o rings in it.
Typical buna-n / nitrile orings have good longevity. They last for years even in twisties.
Viton comes in all kinds of sizes.
FWIW, unless it’s a dive light requiring excellent fit, the exactness is not crucial. It should feel a bit snug when it hits the O-ring, but not shove it out of the groove or be difficult to twist on.
I’ve had O-rings in dive applications last for years with no problem. Some of the stuff that comes on lights though is pretty cheap crap.
If you want to know all about o-rings read the Parker O-ring Handbook.
You can also get X-rings instead of o-rings, apparently they seal a lot better and have less friction.
I’m sorry but thats actually interesting!
I know this is an old thread, but I still want to share my recent findings.
REF:
Marco Rubber NBR vs SIL vs FKM vs EPDM
Marco Rubber O-Ring Permeation Chart
TRP Types of Polymer
NBR is probably the most no-brainer and go-to solution. It’s usually black and is actually the most common o-ring material, easy to get. It has a suitable temperature range, chemical resistance, wear resistance, and gas permeation resistance. You can use common silicone grease for lubrication.
Silicone, while perhaps the most common flashlight o-ring material, isn’t actually that suitable. TLDR: I’d avoid using them. Silicone o-rings often come in clear, red, or black. When they’re black, honestly I find it hard to tell if it’s NBR or silicone, maybe NBR relatively harder.
Silicone offers an excellent temperature range but has poor wear resistance and gas permeability resistance. Therefore, it’s unsuitable for both threads and lenses. Silicone has the highest gas permeability among common o-ring materials, potentially increasing the risk of moisture ingress in high-humidity environments and causing gas or water absorption(sucking in) during rapid temperature changes in flashlights. Additionally, silicone has poor short-term resilience, which may lead to poor sealing when the flashlight expands and contracts due to temperature changes.
My flashlight previously used silicone o-rings without issues in extreme high humidity, but I did a relatively extreme test. When my flashlight was hot, I put it in cold water (I know this is a situation to avoid if possible). With the silicone o-ring, significantly more moisture entered compared to when using FKM o-ring.
add: Also I found that after using the silicone o-ring for a while, the lens always easily sticks to the head, probably because the silicone gas permeability is too high, causing the gas to escape when the light is hot and negative pressure to appear after cooling.
But since flashlight isn’t rocket science, you see many lights using silicone o-rings that function fine. In fact, perhaps because flashlight isn’t rocket science, silicone’s softer property might allow it to fit lager tolerances, which could explain why some manufacturers still prefer silicone o-rings.
Whether silicone o-rings can be used with silicone-based grease is somewhat controversial, likely depending heavily on the formulation or manufacturer’s compatibility list. I choose to avoid this controversy by using PFPE grease or non-silicone o-rings.
FKM is similar to NBR but offers stronger chemical resistance and lower gas permeability, though it performs worse at low temperatures. Depending on the brand and formulation, different FKM o-rings may exhibit slight variations in low-temperature performance and gas permeability. FKM’s wear resistance is generally considered comparable to or better than NBR. I’ve now replaced most o-rings in my lights with FKM, whether for lenses or threads. FKM’s strong chemical resistance means it works fine even with lithium-based mineral oil lubricants. While most FKM has lower low-temperature performance, it’s still rated to -20°C, which is sufficient for my environment. Also at these temperatures, liquid water is rare and humidity is typically low.
EPDM offer better resistance to hot water and steam, along with low gas permeability and cold resistance comparable to silicone. However, its chemical resistance is weaker. If your environment involves exposure to fuels, mineral oils, or cleaners based on these substances, it may not be the best choice. Since I don’t use flashlights in hot water or saunas, I haven’t tested this myself.
Supplementary: since lubrication can reduce gas permeability, I also use lubrication for lenses o-ring, actually this is also a common practice in the watch industry. I’d recommend using PFPE-based grease (e.g. Krytox™) whenever possible, as it is compatible with almost all O-ring materials. Silicone-based greases can be a potential risk with silicone o-ring, may or may not, depending on the formulation.
Also, I found the compatibility tables for these two greases that are often recommended by the community.
I wish flashlight manufacturers would list not only the material of the o-rings used, but also their size. It sucks not knowing which ones can take silicone grease, and which can’t. Or what size they are so I can replace all of them on every light with the same type so I need only one type of grease.
I think only my Eagletac G25C2 MKii explicitly states to use silicone grease on the o-rings. Nothing else said about my 20 other lights.
Gas permeability doesn’t really matter when submerged (except if the flashlight was so hot, the water boiled immediately :wink: ).
I like Nitriles. For flashlight purposes, FKM is probably the toughest and least reactive, but I like my threading actions smooth, and non-reactive to silicone.
I didn’t say too much in detail to avoid making my words too tedious, also perhaps sucking-in is a more intuitive word than absorption.
Generally, flashlights shouldn’t be immediately submerged in water after high temperatures. One reason is that internal pressure increases during heating, causing some gas to escape. When rapidly cooled, a negative pressure forms inside, hence sucking in air and water. Theoretically, if we use low-permeability o-rings to prevent gas from escaping at first, negative pressure is less likely to occur during rapid cooling.
added related info
