BLF SRK FET v3
A very versatile dual/triple channel driver for Sky-Ray-King style flashlights.
An adaptation of the BLF SRK FET v2 by RMM, which evolved from the original BLF SRK FET driver by Mattaus, Comfychair, WarHawk-AVG and many others.
Latest Version: v3.6
with Vias for a Programming Key
Signature part is still the QuadPad, that allows to freely use Pin6 and Pin 3 of the Attiny for dual or triple channel with the FET and/or the bank of 7135s.
(picture)
Version History
v3(.0)
First version, introduced in this post.
Triple Channel and LFPAK56
v3.1
Narsil support, became outdated quickly after DEL’s testing of FET drivers
v3.2
Support for ATtiny 25/45/85 (Narsil) and DEL’s R5
This version kept most features of the BLF SRK FET v2,
as well as several redundant component places for testing purposes
v3.3
Updated version featuring
- Triple Channel with 11x AMC7135
- LFPAK56 MOSFET
- Supporting 13A and 25/45/85 (Narsil)
- R5 for ringing protection
- Indicator LED at MCU pin#3 or pin#7
- Dedicated bleeder resistor from Bat+ to GND
- Wider path from GND to FET source
v3.4
Optimized for High Current
v3.5A
C3 and C4 added
v3.6
Vias for Programming Key
Performance optimizations
BLF SRK FET v3(.0)
First notable change is the use of an
- LFPAK56 MOSFET
Then there are
- 9 additional AMC7135 (Q2-10) for a high mode without PWM
And you can use
- Pin3 as third channel and connect either the FET or Q2-10 to it
Pin5 is hardwired to the single 7135 (Q1) for the low modes.
Pin6 and Pin3 can (using a fancy 4-pad-connector) alternatively be connected to Q2-10 or the FET. Use Pin6 for the channel you want to PWM, be it the FET or Q2-10. Use Pin3 for the channel you want to just switch On/Off.
You can still use it as a dual channel SRK FET driver with LFPAK56: Connect Pin6 to FET using a zero-Ohm-resistor and you have all the functions of the v2 driver but can use the NXP MOSFETs.
But the additional 7135s are where the fun begins:
The OTC was just for testing.
This particular driver has the FET connected to Pin3 and Q2-10 to Pin6. It has 6 modes:
Off - [0mA] - (Pin5, Pin6 and Pin3 OFF)
Moon - [~1mA] - (PWM-2 on Pin5, Pin6 and Pin3 OFF)
Low - [35mA] - (PWM-34 on Pin5, Pin6 and Pin3 OFF)
Medium - [350mA] - (Pin5 ON, Pin6 and Pin3 OFF)
High - [3500mA] - (Pin5 and Pin6 ON, Pin3 OFF)
Turbo - [All-In] - (Pin3 ON, Pin5 and Pin6 OFF)
Moon and Low use PWM at 19kHz (9.6MHz, Fuse7A, PhaseCorrectPWM, Divider1).
Medium switches Q1, High switches Q1 and Q2-10, Turbo switches the FET.
I could now PWM Q2-10, but I don’t need to: the mode spacing of 35-350-3500 is still my favourite.
Oshpark links, eagle pics and changelog later. This driver lies on my workbench and begs for attention… :))
EDIT:
Eagle Layout
A closer look to the main section
