When you click the shortened link to a pre-populated cart, it adds the items to anything already in your cart from your last visit. Delete cookies and/or manually clear/create a new empty cart before clicking the shortened links.
...is not the correct link! The link has to be the one that shows in the little pop-up box, NOT the URL you get in the address bar after pasting in the shortened link.
This leads to the main OSH page, yesterday it was a broken link!
Anyways, I ordered those other switch boards and now I wait, OSH says
they should be back from fabrication on May 5ā¦
Those little SOT-23 sized FETās thatās in the 15DD cart, are they only needed for the 15 and not the 17 or 20 because of the physical size or does the normal 70N02ās not work with the 15DDās for some other reason?
Just size. The control side is the same on all these - same MCU, same resistors, everything the same as the Nanjg 105C. Only the power-handling, high current side is different.
This is what happens with the big TO-252/DPAK on a 15mm board:
The original version doesnāt provide any benefit. I removed it just to avoid duplication, clutter, confusion. I didnāt notice that a link to the original was still up there.
Comfychair reported (post #539) that he could still see light through the vias despite the soldermask over them. On v2 you can solder over the vias on the back.
Oh, and if you ever need a different size just let me know. Changing the board size is quick. Down to about 9.5mm dia at least.
I think Iāve fixed all the links in the op carts and done some other updating. I notice the large cap is no longer in the cart for the SRK. Is the SRK version good to go?
Forgot to say THANKS Helios, I requested this boards long time ago and after that just didnāt have enough time to follow all threads here, didnāt even noticed that you made this boards.
I ordered 9 boards and this tact switches from DX (www.dx.com/p/275664) :party:
If you put the Nanjg's 'R1' (19.1k) where it says 'R1', and the 'R2' (4.7k) where it says 'R2', the MCU will detect a 4.1v battery voltage as 6.7 volts. The traces are good, just the silkscreen labels are swapped around. Put R2 where it says R1, and R1 where it says R2, and everything works fine. :p
Nice catch, I havenāt looked at mine yet. USPS lost the first set for a week and the folks at Oshpark sent me new ones that should be there when I get home. Now ill have six and gave away most of those little fets. I think Matt may have forgotten to swap the labels when he rerouted the trace.
From the photo, it looks like there are other problems with the 15DDā¦ pins 1,2,and 3 on the processor look like they are all connected to ground. Pin 1 is RESET and will turn off the processor. Pins 2 and 3 are configuration stars and should not be permanently wired to ground.
Hey guys Iām giving away the 3 15DD V2ās I got, if any of you main guyās needs one you can have it without being in the contest (however your still welcome to join if you just like contests). No stipulations on them & free shipping.
There's no ground plane there, I used weird side lighting to try to make the traces stand out to show which resistor has the path to ground. There's nothing under pins 1/2/3.
