Darn. Iāll fire away an email to them. Do the same, the more people that point it out the more likely it will get fixed in the next version. support@cadsoftusa.com or support@cadsoft.de.
Try Mouser.
You might check with Richard and/or Wight as to which ones can be used as alternates. Thereās a few thatāll work as well or better. Iām not gonna say cause Iāll probably get it wrong.
There are lots of different ones that will work. What you are really looking for is a low gate charge and low on resistance at 4.5v, which gives some indication as to how it will perform in our applications with relatively low gate charges. I am using the IRFR3711ZTRPBF FET now.
Obviously buying in bulk from Mouser or Digikey will net you a better price than buying from me. If you are going to build a lot of drivers, that's what I'd recommend doing.
And here I was recommending AOD510 in another thread just today. Oh well. (I donāt think Mouser carries any AOD brand products.) I really donāt have any other DPAK sized FETs in mind, having switched to LFPAK56 & similar for my own designs. Pilotdog68ās suggestion of IRFR3711ZTRPBF is probably the best bet for those BLFxxDD drivers which use DPAK. RMM has them and they are also in stock at Mouser.
Thanks to all here who shared their experience and knowledge. I just want to tell with pride and joy that I got my first humble driver up and running.
Special credit with this goes to member wight, who provided invaluable information and took the time to help me through several obstacles in Eagle. I think it is fair to say that without his help this driver would never have seen the light of day. So again, thank you, Alex.
Itās basically wightās 22mm 16x7135 driver, stripped down to 12x7135 to gain space for a larger spring pad and larger cable holes and pads, more space around the MCU for the clamp, while slightly reducing the diameter of the 7135s, so it can be filed down to fit even 21mm.
Picture shows the first 3 samples, I made a 24mm variante with a guiding ring for filing, as I needed a larger size for my test lights. Left is a fully transferred Nanjg 105c plus OTC, soldered with iron. Middle is a 12x7135, soldered with my new heat air blow gun thingy (Youyue858D+). Right is a 7x7135 with Zener Mod for an Ultrafire F10 with MT-G2.
They all work! Itās been like Christmas.
As these were a test run, I was pretty happy. But I already reworked the design, as I first went with 0603 components which are very difficult to handle. Will be 0805 now. In addition I improved some more like current paths, the position of components, the size of the text. Still in transit from OSHpark, but already obsoleteā¦ need to be tweaked for multiple PWM channels.
