Hey fran82, my order for the AA-S1 just shipped from DX.
Thanks medieval, probably I will order one, I love it!
Another petition (sorry) when it arrives comment about it, the tint of the color, the quality, if it has clean or dirty threads... etc...
Thanks
Will do. I'm sort of concerned because Vectrex said he didn't like the yellowish tint to the light.
I think it can not be possible........ the light produced by the AA-S1 is "slightly" warm white, not yellow.
I have seen the photo posted by you showing yellow light in the left and white on the right. It can not be the AA-S1. If really is the AA-S1it can be due to a defective/second class OGD LED.
I have 2 flashlights with golden dragon. On BOTH the light is white, but not cold white, slightly warm white (only a bit warm). I can not notice any yellowish tint on any. Probably he received a defective one or a flashlight with second class OGD LED.........
OR can be that the LED mounted in that flashlight is the 5000K OGD LED instead of the typical 8000-9000K OGD LED
Dug out all the Osram LED devices I could find easily.
Tank007 E07, Uniquefire AA-S1, Ultrafire RL-118, Tank007 E07, Trustfire F22 (Which is a Cree with a very nice beam). All apart from the RL-118 are being run on AA NiMH
Turned off all artificial light
These colours look about right on my screen. If I had a larger white object and a room I could darken, I'd take the shots at a greater distance. Maybe the next time I borrow a projection screen.
The TrustFire F22 Osram LED? In DX page claims Cree R2
And probably newer AA-S1´s are shipped with a warmer LED
Which is what I said above the pic - just for comparison.
Don't put too much weight on my words. Maybe I just got unlucky and received a bad one, or it's personal preference with that tint. What I don't like ... it might be perfect for you... and the S1 is a well built light. But you can clearly see on that second beamshot from Don that the tint is different to the Tank007's and in my experience it's not only due to the GITD O-ring at the front. If you don't like cool yellow-green ... this might not be the light for you.. at least the batch Don and I had. We need more beamshots from other members who also have the light to verify this.
Thanks for the beamshots Don btw
As I already said, I'm quite sure the manufacturers don't use regular tint binned GDPs, so I wouldn't expect one batch of S1's to have the same tint. I'd say it's just a different emitter lottery than with (also cheaply supplied) Cree's, with the benefit of potentially getting some nice and creamy tint, but there is also the possibilty of getting some toxic greenish etc. stuff.
I could be wrong with this of course, lets collect S1 beamshots :)
I don't want toxic green stuff here.
The pics from Don doesn't look too bad. Kind of looks like my Trustfire F23 tint.
As I said, I think that (in the picture) the left beam can not be a WARM white OGD. It must be a YELLOW OGD. Or is a exaggeration made by the camera....
It is extrange, is more yellow than warm white......... I looks as an incandescent bulb (but it is not, is a LED). Pure yellow
OK, Vectrex, the yellow color is produced both with Ni-MH and 14500?
The solution to solve this "enigma" is to dismantle the flashlight, and look the "numbers" written in one side. Then google them to guess what bin/quality/batch of OGD is
(is easy to do, you dont have to remove the emitter, only unscrew the pill and lift up the plastic protector that is over the LED
fran82, I think I don't understand what you mean. Incandescents don't emit yellow light, but warm white. Were you referring to the Black Cat beamshots I posted at all?
Also, are you referring to that tiny alphanumeric code that is printed on Golden Dragon emitters? Do you have any information about this?
OK, about the alphanumerics codes, in the DX product description page (in the page of AA-S1) you have explanation about them. Also can be found in google.
About the other thing. OK incandescent lights produce warm white not yellow. I cant not express correctly because I am Spanish, my English is not good.
I am trying to say, that in that picture, the left beam (FOR ME) is not warm white, is YELLOW!..... so if that beam was produced by an AA-S1, it can be that is the LED/driver defective, OR the new batch (from latter July or August) are shipping with an extrange tint of Osram Golden Dragon (probably the 5000K one)
ALSO, I know that the Black Cat can be found with several colors, including 2 tones of white: 5000K and 8000-9000K
That beamshot on the left is similar to real warm tint led's (~3000K). It's not the 5000K that KD claims.
Often when people say "warm", they mean warmer than WC. So anything from WH to neutrals is "warm", and depends on context.
8000K is a extremely "white" (practically purple/blue light). CREE WC whites are 6000K-7000K.
Ok, we need to clear some confusion. The picture I posted was from phlowcus's Black Cat, not from the AA-S1. I was using that picture to ask if the AA-S1 produced that yellow color. Agenthex and Vectrex (wow, your names rhyme!) both said that the AA-S1 does not produce that warm yellow color, but produces a cool yellow, off-white color.
Hm I tried to find out about these codes some time ago with no luck and I can't find any information on the DX page neither.
OOOOK OOOOK OOOK
I was wrong, I read this thread from the begining, was my mistake. The photo is showing 2 black cats, the left with warm white LED and the right with the almost-cool white.
I have 2 flashlights with OGD. The zooming 3W wich produces veeery cool white and the black cat that produces cool white but with a slight! warm tint.
About the codes:this is taken from the forums of the product:
"BTW, I found a datasheet of Osram's Golden DRAGON Plus LW W5AM
LED that is used in some flashlights, but I don't know is it
the one inside the AA-S1.
http://catalog.osram-os.com/catalogue/catalogue.do?act=showBookmark&favOid=0000000500006f180001003a
Short summary:
- Optical efficiency efficiency 63 lm/W (typ.) @ 350 mA
Maximum Ratings
- Forward current(max.) If = 1 A
- Vf @ 1A = ~3.93 V (according the datasheet curve)
- Power consumption Ptot = 4 W
My comments:
- Driving LW W5AM at 1 A (~ 4 W) is still in the specs.
5 W or more (when 3.6 V cells is used) is not .
- The efficiency is apparently worse than CREE emitters.
(edit: newer bins are available with better efficiency)
You were right about OSRAM's bins. There are more on a newer LUW W5AM datasheet:
bin / lm (@ 350 mA)
KX 71-82
KY 82-97
KZ 97-112
LX 112-130
LY 130-150
(Brightness groups are tested at a current pulse duration of 25 ms and a tolerance of ± 11%.)
LX has minimum efficiency of 100 lm/W then? Not bad.
KX, KY, KZ & LX bin LEDs are sold in Digi-Key so they all should be available.
KX seem to be priced 3.60 USD when bought in quantity of 200 pcs, LX is 4.65 USD there.
BTW, Digi-Key promises "Luminous Flux 131 lm" from LX.
Best KX or worst KY would in theory give 160 lm @ 700 mA (1.95 * [lumens @ 350 mA]), what DX promises from AA-S1.
I found a picture http://chows.smugmug.com/photos/355804212_wJLhL-L.jpg from another forum http://www.cpfmarketplace.com/mp/showthread.php?t=182549 which, I guess, shows what you wrote earlier about internal build-up. They also discuss about the same emitters we have done here. "
SO, If you have access to the LED in your AA-S1, take the bin code, and google it. You will find the datasheet of your bin.
Well, i knew about the binning, unfortunately the codes on the emitters don't seem to have to do anything with that.
I had already come to the conclusion that these codes are just a serial number that only Osram can 'decode'.
And ..... Anybody knows to difference the OGD by the divissions they have in the die?
I know that exists 3 types of Osram Golden Dragon:
1) Golden Dragon
2) Golden Dragon Plus
3) Golden Dragon Plus Ultra
Probably the divissions of the die declares which is.
If only has 1 line (2 divisions) probably is Golden Dragon.
If has 4 lines (5 divisions) probably is Golden Dragon Plus
But I have not seen a GDPUltra so I dont know if it has more lines (divisions in it) . I am talking about this:
http://www.forolinternas.com/viewtopic.php?f=5&t=207&start=20#p1326
Do you see the draw showing a pseudo-die of a OGD P LED?
