Panny PD's safety question... inserted into carrier wrong by accident!
So went out to use my eye40vn tonight. Put the batteries in (4 Panasonic Pd’s). Less than a minute after turning on and walking outside, the battery tube was very hot.
Fearing the worst, I opened it up and immediately removed all batteries from the carrier and onto the grass. They were all very hot.
As careful as I always try to be with unprotected batts, It appears that I must have put one in the wrong way. The battery carrier is a 2s2p setup.
Yes I am aware of the dangers of unprotected batteries. That’s why they are Panasonic’s.
Testing the light with other batteries and it works just fine.
Think they are still safe to use? They only have one cycle on them.
My current stance is to recycle them, but wanted to hear your thoughts.
im sure you will get varying responses… personally i would recycle them… for the cost of 4 new pd’s its worth having peace of mind that you wont have a battery fire or get injured
are they ok to use again? I dont know… depends on how bad the short was, depends on how hot they got…. depends on if there is internal damage etc… at the very least i would think they would have built up more internal resistance from the intense current… also they are probably for sure not safe to match in a 2s2p config now
chalk it up to a simple mistake and be happy nothing blew up and move on :slight_smile:
thats my humble personal opinion :slight_smile:
I’d keep them, but then again, I’m also slightly insane. A discharge test before you consider recycling them wouldn’t hurt I guess.
On a side note, I’ve always worried about putting a cell in the wrong way with those parallel or 2s2p setups, especially when doing a battery swap in the dark. I guess that’s another reason why protected cells in multi-cell lights are a good idea.
Yep. I’m taking it as a $30 life lesson and tossing them.
Just wanted to see what you guys thought.
The Panasonic white paper said that they tested a dead short and the battery didn’t vent…right?
That’s why you buy name brand batteries.
It sure sounds like an easy mistake to make.
In the interests of data collection it would be nice to do some tests on these cells. I don't have a "proper" Li-Ion charger to run discharge and capacity tests but it sure would be nice if someone else (perhaps more local to you) could do this.
Rather than simply toss them, a test of this kind could give us all some useful information.
I'm just glad you used Pannys and not ****fires!
Your one lucky dude. Well if you where that lucky you probably would have stuck the battery in backwards. :slight_smile:
Seriously though that could have ended very bad. I don’t believe I would use them again either. The damage could have already been done to the cell to rear up later on. Read this. Not the same batteries I know but it can happen. Another reason protection circuits should not be relied upon especially with china batteries.
I think they are still safe to use but I think they have lost capacity. These cells are very tough. But if you can't test them, better get rid of them.
So I went outside to test voltages.
One at 4.02, right about where the batteries all started.
The other three were at 2.3 and dropping, one at .96 and the other at a flat 0.00.
Looks like whatever safety Panasonic had built in tripped.
So off to the recycle bin they go.
I thought you said they were unprotected?
If the protection circuit has tripped you can reset them.
I would still use them, in low draw single cell lights only. Use caution when charging them and using them, if they have low voltage, low capacity or get warm while charging or using I would recycle it.
-Jamie M.
It sounds like the fail safe tripped on the 0.00 battery. When internal pressure increases past a certain point the battery physically "disconnects" itself.
Ohhh fancy, never knew they had that type of “protection” in them :slight_smile:
-Jamie M.
They are absolutely unprotected.
They are just well designed unprotected.
Sorry I should clarify. Most lico li-ion have this type of fail-safe. I believe some chemistries like IMR do not. If anyone knows otherwise feel free to correct me. I still would not take my chances with a fail safe as seen from MEGAULTRAFire explosions and vents.
There are at least two kinds of individual cell protection. The kind commonly referred to by the term “protected” is an add-on circuit that is often put on by a third party if the cell is a major japanese brand. This protection is supposed to keep a cell from discharging too low, being over charged and from discharging at too high a rate. It adds some length to the cell and can usually be identified by the metal band running the length of the cell from the +ve to the -ve. While useful, these protection circuits can vary in quality and anyone who has had one fail soon learns not to rely on them.
I think Calvin was referring another kind, known as a PTC. The Positive Temperature Coefficient (PTC) is sensitive to internal cell pressure and temperature and it is intended to prevent thermal runaway. It will break the circuit when it is activated. Most Li-on cells, even laptop pulls, will have this PTC built into them.
HKJ has a nice article and diagram on the subject.
http://www.lygte-info.dk/info/battery%20protection%20UK.html
Edit: fixed link.
Very interesting, never knew that existed.
Link no workie :frowning:
-Jamie M.
Wow, cool. Thanks for the link :slight_smile:
-Jamie M.
glad you notice about it or else you end up with a bang :open_mouth:
Well now that people learned something I don’t feel as bad about frying my batteries.
Always buy quality cells folks!!!
