Parco E4-Indoor LED Par Light RGBAW
Specification
Power input:AC 90-260V,47-63 Hz
Output:24V DC
Maximum Power Consumption:240W
PWM frequency:>4KHz
Control signal:DMX512,32 bit precise dimming, smooth in low DMX Value dimming, not Jumping, no vision shock
Channels:4CH,5CH,9CH
Function effect:dimming,strobe,gradual change,sound active
Light source:60pcs*3W RGBAW LED, 5120 Lumens output
Beam Angles Optional: 10°,15°,25° 45° 120° 160°,25*65°Etc.
Protection Rate:IP20
Housing material: Die cast aluminum
Housing color:Matt Black/Glossy Silver
Accessories: Hooker and Iron chain
Weight: 9.2 Kg
Size 1: L*W*H=Φ315*270mm for double handle portable version,
Size 2: L*W*H=Φ315*310mm for single handle and hook Version
Operating temperature:-20℃ - +55℃
Life Span: 50000~100000 hours
This product comes from:
http://www.longmanlight.com
FeaturesIntegrated design of reflector, more stronger, save more space and transportation cost
Whole lamp body fully used as heat sink, make sure LED Longevity
Application: Portable or pendent light, Stage Par light.
Standard allocation: Hanging from roof, also could use double Handle as portable lights,Par lights.
Could customize 126 PCS 3 watt version.
The very strong feature:Integrated design of reflector, more stronger, save more space and transportation cost
WOW! It comes with a hooker and an iron chain! :party: J) >)
