JasonWW
(JasonWW)
December 6, 2017, 12:41am
10281
Texas_Ace:
I just installed the xhp70.2 in the prototype, still have some testing to do but the results are promising so far.
A quick throw test showed it at ~1300m of throw.
Cool! I was predicting about 1200m, but 1300m is even better. Maybe with some refocusing it will hit 1400m.
DB_Custom
(Dale)
December 6, 2017, 12:46am
10282
Cree’s recommended solder paste design is for a luminaire with isolated ground, not for our flashlights where we want to keep positive and negative isolated from ground so we can control output through PWM or regulated current control. This is why SinkPAD has the 12V version with bridgeable pads.
JasonWW
(JasonWW)
December 6, 2017, 12:48am
10283
Maxtoch should have a 12V in 32mm. We would just need to add the led.
A factory version would be great, especially with a matching centering ring. Would they do CW and NW?
I think interest is low right now, but once people get their lights and see your pictures and stuff, interest should go way up. It makes the light more practical. A bigger hotspot at closer range means you don’t need binoculars to see what your aiming at.
Texas_Ace:
Have not testing lumen output yet but should be around 6000+ with the new sense resistor and looks every bit of it.
At close ranges the xhp70.2 got rid of the donuts hole completely. At longer ranges while not a hole, it is still a bit darker in the middle of the hotspot. I will play with the focus tomorrow to see what kind of improvements can be made.
Tint is also pretty good for a latest gen Cree. It does have some tint shift around the hot spot but the hot spot itself looks great.
I will report on it more after I get the full test done.
TA, can you tell me what value sense resistor you are using for the XHP70.2? Thanks!
zelee
(zelee)
December 6, 2017, 12:54am
10285
last time i use DHL, they charge me $40 for a $80 item :disappointed:
they surely love money :money_mouth_face:
Jerommel
(Jerommel)
December 6, 2017, 12:58am
10286
How about these “Laird thermal pads”, to isolate electrically but not thermally:
(0.1mm thickness should suffice)
Texas_Ace
(Texas_Ace)
December 6, 2017, 1:24am
10287
To reach 5A you would want a ~.047ohm 1% sense resistor IIRC, I would have to check again.
I have a bit higher current in mine right now in order to stress test the driver under worst case conditions.
Texas_Ace
(Texas_Ace)
December 6, 2017, 1:25am
10288
JasonWW:
We have not got that far yet, only that they are open to the XHP70 mod.
I agree that it is a nice version and the large thermal mass and 8 cells means it can actually handle the heat for a little while as well.
Jerommel
(Jerommel)
December 6, 2017, 1:34am
10289
Well, my ThorFire S70S runs about 6 Amperes on a CRI80 XHP70, and it takes quite a while to get warm.
I have never gotten it actually hot, just quite warm. (i did incorporate the reflector in the thermal path too though)
This GT has more mass and (more importantly) a LOT more surface area, so i can’t imagine it getting hot at all.
Maybe when you’re in a tropical climate?
So my question is: Does your GT with XHP70.2 get hot at all?
Texas_Ace
(Texas_Ace)
December 6, 2017, 1:45am
10290
Jerommel:
Yeah, it starts getting warm after a few minutes and it would get pretty darn hot it you let it run for while.
teacher
(teacher)
December 6, 2017, 1:50am
10291
+1 … Thank you! Good to know he has not croaked……… :+1:
Texas_Ace
(Texas_Ace)
December 6, 2017, 2:00am
10292
Here is a list that Neal is working on of the orders so far. He said there are still another ~30 orders he needs to verify and update.
Sheet1
number ,BLF name ,shipping option ,BLF GT qty ,35E set qty
218,BeardedRaleigh,DHL ,1,1
222,battletross ,DHL ,1,1
564,bobdotorg ,DHL ,1,1
261,juaquin ,DHL ,1
487,JM87,DHL ,1
15,djburkes ,DHL ,1
584,boostedsubie ,DHL ,1
769,Boldo ,DHL...
The yellow highlights are orders he has not received (or not updated yet) the phone number for.
Please check the list for your order if you have any questions.
JasonWW
(JasonWW)
December 6, 2017, 2:08am
10293
Jerommel:
Your forgetting the voltage difference. Your S70 is doing 6A at 6V. That’s only 36 watts.
The GT would be doing 5A at 12v which is 60 watts. Almost double the heat of your S70.
Hi Jason, convoy L6 at 7 amps, would it be 42 watts? I always thought that they were 8.4 volts x 7 amps …
adsum
(adsum)
December 6, 2017, 2:40am
10296
Texas_Ace:
BLF GT balance payment confirm.xlsx - Google Sheets
I`m 14th on that list and it says just “register” in the place of my shipping method when all else says “Registered” or DHL.
I did chose Registered shipping so maybe it is just a slight typo and is actually proceeding the right way.
Volts Times Amps Equals Watts, so if the driver you have in the L6 is running at 6V @7A , that would give you the 42watts
teacher
(teacher)
December 6, 2017, 3:13am
10299
I bet poor Neal has had to work his tail off to get that list together!!
Hats off to Neal……… :+1:
xCentrino
(xCentrino)
December 6, 2017, 3:15am
10300
I’m not wearing a hat…
Found one :face_with_monocle:
and now off
