Yes, you have to be clear because people jump to wrong conclusions very fast. They will be asking to buy it with the xhp70 option. Lol
Swapping the emitter out is easy, you just unsolder 2 wires and unscrew the mcpcb. Swap it, put the screws back in and then solder the 2 wires back on.
You’d need a 12v version of the xhp70.2 on a large diameter DTP copper mcpcb. Probably a Maxtoch.
Maybe a new centering ring will be needed or maybe the stock one can be enlarged?
Then to up the output from the driver from 2.5 amp to 5 amp you need to remove the driver and solder in a new resistor. That should be good for about 6,000 lumen.
I’m sure we will get more details from Texas_Ace soon. Maybe there will be a new thread for GT mods.
The Maxtoch store on Aliexpress. I think this is the one. I’m guessing there is no difference in the star design for 6v and 12 volt and it’s all inside the led. Nope, this is the 6 volt version.
MAXTOCH Copper MCPCB Cree XHP70 MK-R2 MKR 32mm x 1.6mm Direct Thermal Path Copper Board
It’s actually a difference in the MCPCB, the emitter is the same regardless. There is a separation in the way the electrical pads are on the MCPCB which allows a 2S2P for 12V. So if you want 12V, you have to have a 12V set-up MCPCB.
I’ve managed to make it onto the list at #1280. Signed up for batteries, too.
I can’t believe that so much interest has been generated in such a niche flashlight. I’m going to hazard the guess that the group over 1000 will probably be the last wave before any public distribution begins, if there is any. I’d like to hope that this much interest is enough to make the entire project worthwhile from Lumintop’s perspective. Or are the numbers still too small to make a difference in the grand scheme of things?
Hats off to the entire team for keeping this together!
There you have the problem of giving the thermal pad half the voltage, because it is connected to the pads, and to the body of the light.
So it’s a bad recommendation, because you will short circuit half the LED and probably blow up the driver too.
I just installed the xhp70.2 in the prototype, still have some testing to do but the results are promising so far.
Have not testing lumen output yet but should be around 6000+ with the new sense resistor and looks every bit of it.
A quick throw test showed it at ~1300m of throw.
At close ranges the xhp70.2 got rid of the donuts hole completely. At longer ranges while not a hole, it is still a bit darker in the middle of the hotspot. I will play with the focus tomorrow to see what kind of improvements can be made.
Tint is also pretty good for a latest gen Cree. It does have some tint shift around the hot spot but the hot spot itself looks great.
I will report on it more after I get the full test done.
Lumintop has said if there is interest they would consider making a batch of XHP70 mcpcb’s to make this swap fairly easy. At this point you would need to either customize a normal mcpcb or have someone do it for you.
This is what the prototype mcpcb is, it uses an an SD75 mcpcb with the pads cut to convert it into a 12v mcpcb. You have to be careful when reflowing the LED but it works fine.
