[PBCC] BlitzWolf BW-P3 10.000mAh 18W QC3.0 powerbank
BlitzWolf was nice enough to send me a BlitzWolf BW-P3 on the day of release, so I could put it though the wringer and review it in this Power Bank Capacity Check, a series of powerbankreviews I've been doing for some time in Dutch, but wanted to try to do in English as well. So here we go, a first attempt at a review in English.
As you might have guessed from the model number, this is BlitzWolfs’ third powerbank, a successor to their BW-P1. With an upgrade to QC3.0 and the addition of a second (5V) USB-port I think this might be a worthy successor too.
Unfortunately, the first batch of production has an issue with the 5V/USB port. As one of the first ones to receive it, I kind of discovered this issue; the port stops output after some time, this can be 90 seconds, but it can also be 5 minutes. Pressing the button restarts output, but this keeps happening until the powerbank has reached a certain level, I guess. The QC-port does not have this issue.
At first we hoped this was a standalone issue, one bad unit, but after a couple of days I found some users that had the issue, and complaints were coming in at Banggood.
As an official BlitzWolf dealer, BangGood has told me that powerbanks that are shipping now do not have the issue.
Unboxing
www.youtube.com/embed/VmpykEuJwV8
A brown cardboard box bearing the BlitzWolf logo, with in it : a user manual, a warranty card, a micro-usb cable and the powerbank itself.
Top and bottom panel, with ports, powerbutton and specs…
The casing, in anodised and sandblasted dark purple aluminium is really impressive and makes this powerbank kind of a looker. No sharp edges or corners to hurt your hands and/or ruin your pocket.
Specs
Model: BW-P3
Capacity: 10000mAh/37.44Wh
Power: 18W (two USB ports total)
Battery Type: SANYO/Panasonic Li-ion Battery * 3
Input: 5V/2A (max)
Output USB: 5V/2.4A (non-qc,universal)
Output QC: (QC3.0) 3.6-6.5V / 3A 6.5-9V / 2A 9-12V / 1.5A
Size:102 x 61.5 x 21.3mm
Weight: 225g
Performance 5V
The first and only charging test in this edition of PBCC will be at 5V/USB, because this powerbank can only be charged via 5V/USB.It was done after discharging the powerbank right out of the box.
It took 5 hours and 52 minutes, reaching a capacity of 40,639Wh (7.916mAh @ 5V) which looked like it was a little on the low side.
The discharge test resulted in 31,454Wh (6.439mAh @ 5V).
Performance QC (12V)
Charging this powerbank using QC is not possible, it only accepts 5V/USB at 2A max as an input. Hence, the absence of a QC charge test.
Discharging the powerbank using a Xiaomi 20.000mAh powerbank as a load resulted in 28,505Wh (2421mAh @ 12V)
But, these results all seemed to be a little on the low side for me, so I retested the powerbank using a ZKETech EBD-USB+, with the following results :
Charge test 5V/USB : 39,94Wh (7.742mAh @ 5V)
Discharge test 5V/USB : 31,38Wh (6.419mAh @ 5V)
Discharge test 12V/QC : 28,94Wh
Not that much of a difference. After comparison of all results to another 3-cell 18650-based powerbank in the Google Sheet this powerbank performs a tad bit better than it’s competitor that does not have the addition of either QC or a second port.
If you’d like to compare the results of this PBCC this the results from my other tests, you can check out this Google Sheet.
The whole shebang…
Conclusion
This beautiful dark purple powerbank performs a little bit better than other powerbanks in that realm. When looking at the percentage of output over input, this even takes top ranking. All that, with the bonus of a second QC-enabled USB-port, makes this powerbank a winner in my opinion, certainly at that price.
This powerbank is for sale at BangGood.
Pity, that there is no QC when charging powerbank. That is big disadvantage.
Mike
QC isn’t likely to help with charging the power bank if it doesn’t pull more than 1.8A in the first place.
Nice review! Did you test the peak efficiency at 5V 1A? It looks surprisingly good at 12V 1.5A, that’s a lot of power.
It does help, at 5V 1.8A the input power is limited at 9W, while with QC 9V 1.5A it can be up to 13.5W.
But it isn’t hitting even hitting the 2A limit at low state of charge. Something else is limiting it.
Thanks for the review. This thing is perfectly sized, what a difference a 3 vs. 4 cells make. The performance is also excellent.
Here’s my measured data using the EBD-USB+.
Charge using a 5 V 2.4 A charger (Olight 1 port bundled with the R50 Seeker)
Charge current: 1.57-1.81 A during CC mode (3h 55min)
Total charging time: 5h 28min
Energy in: 40.84 Wh
Capacity in: 8025 mAh
Discharge at 1,7 A
Time: 3h 49min
Energy out: 32.16 Wh
Capacity out: 6510 mAh
Input/Output efficiency: 32.16 Wh/40.84 Wh = 79 %
18650 vs. 5 V energy output efficiency: 32.16 Wh/34.2 Wh = 94 %
I assumed NCR18650B energy of 3*11.4 Wh = 34.2 Wh
Voltage at different output currents
1.0 A: 4.99 V
1.5 A: 4.95 V
2.0 A: 4.92 V
2.5 A: 4.89 V
Nice addition maukka!
Maybe we should decide on some kind of standard tests, as we all pretty much share the same testing gear.
So all our reviews could be directly compared to eachother.
But then again, the different styles in reviews are what makes this subforum such a nice exchange…
I agree about your comment on size, and is the reason I like the Anker Anker PowerCore+ 10050 Premium Aluminum Portable Battery Charger with Qualcomm Quick Charge 2.0 Technology (3.8 x 0.9 x 2.4 inches) and is sold in U.S. @ Amazon for $35.99.
How one can describe a bargain is certainly a valid debate, but for this power banks size and capabilities I found it a bargain for me.
One thing I also like about the BW-P3 is that when it shows that the charging is complete, it actually is. When the fourth led stops blinking, the bank is full. Some power banks indicate full even though they might still charge for hours in the CV phase.
+1
The Anker I metioned when charging a device is completed the power bank shuts off power.
I also love my Ankers. Astro E5 (2nd gen 16 Ah) and PowerCore Mini+ (3350 mAh). The Blitzwolf closes the gap nicely.
My unit also had problems with the 5v output cutting out. Banggood ended up refunding me the purchase price, which is good. I bought this thing primarily to play with the 12v output, so I’m not in a huge hurry to order another. Yet :slight_smile:
Thanks for your first written review :slight_smile:
It's been a while :)
