Just wondering wether there is a liquid I can use to remove the phosphorus off my dedomed XPL.I have a blue tint on half my emmiter but I want the rest to be blue. Please help!!
Acetone, if you're dead set on using a solvent.
Much easier is to just scrape it off. Take the tail from a small cable tie, cut at an angle so you've got a sharp but somewhat flexible point, and just peel it off.
And don’t stare into the blue light…
I popped dome off of a nichia 219c, looked like a UV light, probably dangerous to look at
Not UV but still dangerous.
That’s exactly what it was not uv.
What’s the danger of using led lighting that has phosphorus still on it? Are we damaging our eyes with daily led use?
No, the phosphor coating filters the damaging light, converting most of it to the red, yellow, green, etc. colors, and letting through some of the blue as well, so that in total you see a white light when it is powered up. The reason for the phosphor is that LEDs can only produce a single peak wavelength of light and in order to perceive white light, you need several different wavelengths combined.
For me, acetone didn’t take the phosphor off. I use it for dedoming because it doesn’t smell as bad a gasoline. When I tried scraping, I killed the LED.
So acetone it is then?\
Fuming nitric acid will probably do.
Except it’s evil
Produces choking toxic fumes: From the acid, and from things the acid reacts with.
If the fumes get you, you may not find out until 8 hours later when your lungs melt.
It’s an oxidiser and causes spontaneous combustion of some materials principally organics.
Safety gloves, be sure they are not latex or nitrile, else your safety gloves can burst into flames. While you are still wearing them. Seriously.
This sounds like a winner!!!
Thanks
I am obviously joking.
