I want to see if I can swap the ATtiny13 out for a ATtiny25 to play with the built in thermistor, but they’re available in 3.9 and 5.3mm widths (0.154 and 0.209in). I don’t have one to hand to measure, so could someone measure one for me please?
why? Is it because I’ll need the extra code space for temperature monitoring? I can’t see any other pertinent differences between the two from a driver perspective, although I am a complete ignoramus when it comes to programming so please point out if I’m missing something.
I remember why now - Digikey doesn’t stock the 45 and 85 in the S1 package size and I needed an SOIC8 clip from Digikey The 25 is also what Nickelflipper’s going to be using for his buck-boost board, so I figured it would be easier to use the same as that, especially as I’m going to try and build up one of his boards. Not great reasons, admittedly, and if I run into space constraints that I can’t work around then I’ll get some from Mouser. Thanks for the advice though!
