Hi
i am about to make an order from FT and kinda confused about what battery is better this Trustfire 14500 or this Ultrafire 14500 please am kinda in a hurry to make the order thank you in advance
and FT is going to send the order via Malaysia Post so will they accept to send the battery ?
I have a pair of those trustfire and they work decent enough for stock flashlights, but would invest a bit more in some KEEPPOWER 14500 and be on the safer side.
Edit, didn’t know FT had Sanyo, go with the batteries chief linked.
Bear in mind those Sanyo’s are unprotected, not good for use in lights which will also run AA without a low voltage warning as they will run them flat and destroy them.
Otherwise, the Sanyo cells are the best quality. Trustfire are generally better than Ultrafire, not always but they are much more consistent in general. Trustfire ‘flame’ 14500s may even match the Sanyos in capacity, but they probably won’t hold up as well over time.
