Pick your top 5 knives from this list of 27 and tell us why you like them.
NAVY KNIVES
Blade Length: 3 4/5"〔98MM〕
Blade Thickness: 1/8"〔3MM〕
Blade Material: 440C
Blade Hardness: 56-58HRC
Lock Mechanism: Monolock
Overall Length: 8 3/5"〔220MM〕
Closed Length: 4 9/10"〔125MM〕
Navy - K605
Lock Type: liner lock
Blade Length: 3 1/2" (90MM)
Blade Thickness: 1/8" (3MM)
Weight: 95G
Overall Length: 7 1/2" (190MM)
Closed Length: 4 1/3" (110MM)
Navy - K501
Clip with stainless Handle Frame Lock
Phosopher bronze bushings for smooth open/close action
Blade Closed: 3 3/8
Blade Open: 5 7/8
Blade Length: 2 1/2
Blade Steel: 440c
Navy - K905
Stainless and Micarta handles
Blade Length:3"
Blade Material: 420
Blade Hardness: 54-56HRC
Weight: 5.4oz
Lock Mechanism: Linerlock
Overall Length: 7 3/4" (197mm)
Blade Length:3 1/4"" (82mm)
Blade Thickness: 3/20" (4mm)
Blade Material: stainless
Blade Hardness: 52-54HRC
Blade Length: 4"〔100MM〕
Weight: 120G
Overall Length: 7 9/10"〔200MM〕
Closed Length: 4 1/3"〔110MM〕
Blade Length: 3 1/8''(80MM)
Blade Thickness: 1/8''(3MM)
Weight: 150G
Lock Mechanism: COMPRESSION LOCK
Overall Length: 7 1/10''(180MM)
Closed Length: 4 1/2''(115MM)
http://www.exduct.com/Navy-Knives/K505-Navy-Folding-Knife.html
Navy - K505
closed length: 4" (102mm)
overall length: 7" (178mm)
blade length: 3" (75mm)
blade material: 440c
blade hardness: 56-58HRC
hand material: stainless steel
http://www.exduct.com/Navy-Knives/K506-Navy-Folding-Knife.html
Navy - K506
Stainless handles with belt clip
Blade Length: 2 3/4"
Blade Material: 440c
Overall Length:6 1/2"
Closed Length:3 3/4"
http://www.navyco.com/eshop_view.asp?id=19
Navy - K631
G10 handles with belt clip
Blade Length: 3 3/4"
Weight: 4.5oz
Lock Mechanism: Backlock
Overall Length:8 1/2"
Closed Length:4 3/4"
SANMUREN (SRM) KNIVES
**Actually the same as the knife below this one but with different handles (no tonto style blade)
SRM Folding Knife,730,Total lengh 163mm,Handle Material:stainless steel,Blade width:22.5mm,Blade Length:72mm,Blade thickness:2.4mm, Blade material:8Cr14MoV,liner lock type,Blade hardness:57HRC+
SRM - 730
**Actually the same as the knife above this one but with different handles (no tonto style blade)
Product Details:
weight:70 g
weight:148 g
Sanrenmu 6-939
weight:120 g
Knife total Length:200mm
Blade length:116mm
Blade Thickness:0.30
Sanrenmu GB-763
weight:80 g
http://www.exduct.com/SRM-Knife-Gifts/T01-SRM-Folding-Knife.html
SRM - T01
SRM survival knife has multifunction knife tool, inclues function:Bottle opener, screwdriver, umbrella rope hook knives, glass cutting, belt cutting blade (half-tooth blade),knife total lengh:16.6cm,blade lenght:7.30mm,blade width:2.4mm,blade thickness:0.24mm, Blade material:8Cr14MoV,liner lock type,Blade hardness:57HRC+
SRM Folding Knife,710,Total lengh 165mm,Handle Material:stainless steel,Blade width:23mm,Blade Length:70mm,Blade thickness:2.4mm, Blade material:8Cr14MoV,liner lock type,Blade hardness:57HRC+
SRM Folding Knife,723,Total lengh 161mm,Handle Material:stainless steel,Blade width:20mm,Blade Length:63mm,Blade thickness:2.4mm, Blade material:813,liner lock type,Blade hardness:57HRC+
SRM Folding Knife,B4723,Total lengh 161mm,Handle Material:stainless steel,Blade width:20mm,Blade Length:63mm,Blade thickness:2.4mm,Blade material:813,liner lock type,Blade hardness:57HRC+
SRM Folding Knife,733,Total lengh 163mm,Handle Material:stainless steel,Blade width:23mm,Blade Length:63mm,Blade thickness:2.5mm, Blade material:8Cr14MoV,liner lock type,Blade hardness:57HRC+
SRM Folding Knife,B4733,Total lengh 163mm,Handle Material:titanium plating on stainless steel,Blade width:23mm,Blade Length:63mm,Blade thickness:2.5mm,Blade material:8Cr13Mov,liner lock type,Blade hardness:57HRC+
Features:
One-hand ambidextrous function
Skeletonized profile
Slender mirror polished drop point utility
Bronze plated back spacer
Locking mechnism: slip joint
Blade style& opener: drop point utility, ambidextrous thumb-stubs
Blade steel: 8Cr13MoV stainless steel (56-58HRC)
Handle spec:dual stainless steel liner, mica inlays, bronze plated back spacer
Blade length:68mm
Open:160mm
Close:92mm
SRM Folding Knife,ALH02,Total lengh 159mm,Handle Material:wooden,Handle length:91mm,handle thickness:10.8mm,Blade width:18mm,Blade Length:62mm,Blade thickness:2.8mm,Blade material:8Cr13Mov,Blade hardness:57HRC+,Handle material: stone wash of light inlaid mica sub-mirror stickers,Lock Type: fool-style opening and closing
GANZO KNIVES
weight:198g
Knife total Length:201mm
Blade length:113mm
Blade Thickness:0.40
BEE KNIVES
weight:160 g
http://www.exduct.com/Bee-Enlan-Knives/L06-Bee-Folding-Knife.html
Bee – L06Bee Folding Knife L06,Side liner lock knife,handle length 11CM, full 19CM,8CR13 Blade,Black & Red G10 handle,with clear back clip.
