I first heard about the DPS5015 6 months ago here.
Budget friendly adjustable bench Power supplies perfect for testing LED’s and other uses!
I was skeptical of it’s performance at first, but was quickly convinced that this unit is the real deal.
So I recently ordered one.
It seems everyone is driving it with plug in power supplies, I thought I would try something different. I will power mine with Li-ion tool pack batteries.
For a case I will use my original Ridgid Ni-Cad 18V, dual bay battery charger.
(I have since cleaned this up of the dirt and grime you see here)
My old Ni-Cads have worn out and I have converted to the newer Li-ion batteries. My old tools are backwards compatible, but this old charger is not able to charge the Li-ion batteries. Time to repurpose it!
For a power source I plan on using a 40V Ryobi yard tool battery.
This battery pack contains 20 18650 cells and is a BEAST. capable of easily putting out in excess of 20A.
I am going to use the old Ridgid Ni-Cad charger as a host for the DPS5015 because with a slight modification, the 40V Ryobi will plug right into it.
This dual bay Ridgid charger was originally designed to accept 12.0V, 14.4V and 18.0V Ni-Cads. Circuitry inside would figure out which pack was plugged in and it would charge them accordingly. Note that Ridgid designed all 3 of those different batteries to have the same plug and socket setup. The tools for each voltage had a system of keys and slots to prevent the wrong battery being used in each tool.
Believe it or not, there is a lot of commonality between Ridgid batteries and Ryobi Batteries. They are made by the same manufacturer!
Here is a Ridgid 18V battery next to the 40V Ryobi. Notice that the plug system on each is the same.
Confident that I could make it fit, the first thing to do is gut the charger.
Remove the screws. It takes a security torx bit to remove them, Harbor Freight sells a nice set, cheap.
What’s inside, someday I will investigate that power supply. 2 channels of nice.
There is a fan and 4 LED assembly that I may be able to reuse in this build.
Previously, the 40V Ryobi would slide into the socket, but something was preventing it from sliding in all the way. I had to find out what I had to modify on the socket in the old charger. I do not want to modify the battery. The battery belongs to a yard tool and I will continue to use it for that and charge it with it’s included charger.
Here is what is preventing it to slide in completely. The flat black square key on the charger is preventing the battery, gloss black, from sliding in all the way.
I have to remove part of this block.
Just enough removed so that the battery will fully insert.
The unit with the battery fully inserted. I plan on mounting the controls for the DSP5015 where the left channel socket used to be.
I haven’t yet decided where to put the binding posts.
And if I wanted, I could still power this with the 18V Ridgid packs. This is a 2.0Ah pack. I also have some 4.0Ah packs.
And even this 24V Ryobi pack will fit!.
All I can do now is wait for my DPS5015 to arrive and wire it up
BTW, in case anyone was wondering, each battery pack has low shutoff circuitry. I could run this until the pack shuts down. I may want to add a separate DVM to monitor the input voltage while it is in use.
I’m hoping there are no gotchas waiting ahead for me. There usually is when going off the beaten path like this. :person_facepalming:
EDIT:
Arranged the words to the title around a little.
May 7th, 2017
Well I received my DPS5015 about a week ago. Only now have I had the time to wire it up.
As I am right handed, I decided to mount the controls on the left side of the case.
Rough cut first then file work.
As I had mentioned, this case has plenty of ventilation both top and bottom halves.
All wired up and ready to go. The color of the bezel sort of matches. Can’t say so much for the colors of my binding posts.
I have had these posts sitting around since the early 70’s. Back then I used to frequent the surplus dealers in and around the Boston area. I was NEVER able to find matching Red and Black 5 way binding posts! The ones I see for sale today are not of good quality, or they cost way too much. Purple = Red and White = Black.
IF I ever do come across Red and Black binding posts, this project will be upgraded.
Here it is with an 18V (21V fully charged) 4Ah Ridgid pack.
Here it is set for 12.00V with the current limit set to 15.10A.
Connected to 2 - 2.2 Ohm resistors in series.(4.4 Ohm), it pushed out 2.69A
Connected to a 2.2 Ohm power resistor is draws less than the current limit, 5.38A. Voltage was maintained at exactly 12.00V
Next I set the current limit to 2.00A while leaving the voltage set to 12.00V
This time because the current limit had been reached, the voltage fell to 8.90V
Everything is working just as it should :+1:
Left to do is mount an input jack for a 19V, 3A laptop supply. The hole for the old AC cord screams out for that jack to be placed there.
I will have to use a SPDT switch for the 2 inputs, battery or laptop supply. That switch will also double as an on-off switch for the battery. There is a very slight drain on the battery when not in use.
This unit is very nice to use. The slope on the control module makes it easy to see and adjust and the binding posts below it are out of the way, yet still easy to connect.
And the performance of the module is top notch.
