A bit bigger than the XM-L colour, but with way more output, ~XP-G size dies, : 1040 lumen for the white chip, 680 lumen for green, 360 for red, 4.7W for blue, this is for 4.5A per die .
Not sure how interesting it will be for flashlight use, at least I'm pretty sure it will be way too expensive
@djozz - nice find. XP-G sized color dies are interesting. I took a look around for single die versions. I couldn’t find any “red” 2 square mm ones in single die packages. I’ll be more interested if they start doing single die packages with those.
Here’s what I did note while I looked:
625nm is as at the upper (more red / more deep / more saturated / whatever) end of Cree’s allowance for their ‘normal’ red LEDs (620nm to 625nm). [I do not see an equiv to Photo Red / Deep Red, although they do have some low power LEDs labeled “Hyper Red” which are slightly deeper.
All the red power emitters (there is one ‘hyper red’ power emitter) seem to have 1mm square dies. They’re all rated for 1 amp and seem to have roughly similar performance to Cree’s equiv product.
Interestingly all of OSRAM’s projection LEDs which I looked at seemed to use amber rather than red!
No that is the old version, less than half the output, the new one above is bigger and handles way more current. It was announced the 9th of december, I'd be surprised if it was for sale already.
i like that cool/warm white version. Built a driver that can be variable output between the warm to cool white dies to custom set the tint you like best.
Up to 2.6 times the brightness from a component surface only 30 percent larger
With an area of 2 mm² each, the chips are twice as large as the previous ones but at 5.7 mm x 6.4 mm x 1.3 mm the package size is only slightly larger.
Imagine that in a zoomie
Even with a 105C/D w/ 4 extra chips…that thing would make some MASSIVE light!
Wonder if a 16/20mm noctigon/sinkpad is available
Technical data (LE RTDUW S2WP):
Package dimensions
(previously 4.8 mm x 5.9 mm x 1.23 mm)
Chip size 2 mm²
Chip colors
Red: 625 nm
Green: 530 nm
Deep blue: 453 nm
White: (x=0.32; y=0.33 to CIE 1931)
Brightness (at 4.5 A, max. DC typ.)
Red: 360 lm
Green: 680 lm
Deep blue: 4.7 W
White: 1040 lm (previously 290 lm)
That’s a cool idea! I’ve contemplated modding a multi emitter light (like a solarstorm 5t6 or similar) like this with a wide range of tint bins of the same emitter. Each led individually switchable to easily show people what LED tints/temps are and how they compare. Might still do this just to use up my stock of variously binned x-mls
