Well, I feel kind of bad about the whole thing, but I am going to scrap the project. It has caused some controversy on the home front, once my wife realized what I was going to do. She's a stickler about "the law", any law, every law, while I am... well.... OK, I don't mind bending the rules sometimes if I feel it won't hurt anyone or if I justify it in my own mind. Hey, that's just the truth. Anyhow, since I don't bite the hand that feeds me, then I will be scrapping the project.
I should have never started it, sorry guys...
I had to replace the H4/2006 low beams in my 2003 Corolla. I did not want to buy the stock bulbs, but I really did not want to pay for the Silverstars or for the better LED bulbs out, with cooling fans.
So, you know how it goes...
I thought maybe I could do something with the stock bulbs. Maybe build something by removing the bulb and keep the housing, so it will still fit into the car like it should.
So, I cut the bulb off, right at the base, leaving the section of metal housing that is molded into the plastic holder. I will clean off the sharp edges later. I just used a fine toothed hacksaw for the cuts.
I also decided to remove part of the back side, to give a flat surface for a heat sink to set against. I used the natural parting line already there, from the molding of the holder. I marked it with a marker and cut it with a hacksaw.
Plastic is easy to cut.
Then I trimmed off the elbow section and used a file and sandpaper to make a nice flat end.
I used a file to clean up the front a little.
The opening in front is now about 10mmx7mm, so I am thinking about cutting a piece from this copper bar. It's 7mm thick and I just need to cut strips off it. This would be where I solder the center pads to the Four XM-L2 leds and it would take heat out to a fan cooled heat sink.
I figure I can go 30-32mm length of the copper bar and that's plenty for adding four XM-L2 leds.
I am fairly lucky with the amount of room I have. I think one of the heatsink fans below will work. I'm figuring four XM-L2 neutral white to warm white wired series, so I can go DD to the stock harness and the fan is also 12V, so everything should work.
You know, I just gotta try!
The more I think about this, the more I hesitate to buy anything for it. I have a box of PC parts, so I think I will just use a heat sink and fan I already have. I also have several used XM-L leds, although they are cool white, but I would at least know if I wanted to take it further and spend the money, or not. I can make up one light and really get to see the difference between it and the stock bulb.
I think that's a more economical idea. -----------------------------------------
