Parts List:
Solarforce L2n (grey) - $12.99 + $2 shipping
M140 445nm diode - $59 - Free shipping
P60 style heatsink - $8 + $4 shipping
Mohgasm 1.8a Driver - $9 + $5 shipping
Total cost - $99.99
Extras:
Small chunk of copper or aluminum to sink the FET(?) on the driver
Spring for positive battery contact
Thermal adhesive
Something to wrap the heatsink with for a tight fit into the hosts head
Assembling your parts:
First thing you want to do is collect the parts above. I also added a 16mm blue boot to the tail switch, and a 14mm blue boot to put over the lens when not in use to protect it. Totally optional, but I like my blue boots.
Next, place the diode module into the heatsink and tighten the set screw on the side of the heatsink.
Now the diode will have three wires: red, black and white. I dont remember what the white wire was for, but you will not need it. I cut it off leaving about 0.5" in the driver cavity. I then cut down the red and black leads from the diode to about 1" and stripped about 1/8" off the ends. The red wire goes to D+ on the driver, and the black will go to the D- solder pad.
But first you will Want to solder a spring on to the positive battery contact on the driver. I had one kicking around that I used. They are cheap, and even cheaper if you strip it off a junk driver you got from a cheap light you upgraded. If you are here, and wanting to build a laser, I am guessing you have some mod supplies around.
Next up, heatsink the FET(?). I had a small piece of copper bar that I got from the member here that sold me the driver. You want to make sure it is smaller than 17mm to fit in the driver cavity, and short enough to not bottom out on the inside of the driver cavity. Also note, if the material will block your solder pads for the diode, you may want to attach it after the next step. I arranged mine so it left the solder pads open.
Now we are ready to solder our leads from the diode to the driver. Tin the red and black leads, add a little flux to your positive and negative solder pads, tin them, and solder them right up. Red lead goes to "D+" and black goes to "D-". Then seat your driver into the heatsink and get a few points soldered from the ground ring on the driver to the heatsink.
Now on to the host.
There is a lip that the glass reflector sits on. It blocks the heatsink from fully sitting in the head, and you will want to file that lip off. You will not need a lens for this.
That is it. Now you are ready to wrap your heatsink with some sort of thermally conductive material to get a snug fit, fit it into your host, attach the head.
Done.
Now you just need to put in two 18350 cells, and you are ready to go.
If you are worried that it is too hard to build a laser, it is not. I found it easier than a flashlight
That said, I do need to go back and address some thermal issues with mine. I need to reattach my FET heatsink, and I need to wrap my heatsink with some copper foil.
Laser guys feel free to correct me on any of this, and if I missed anything. This was my first build, so its all pretty new to me. But I am already planning on my next, either a 405nm, green or red. Not sure yet
PICS TO COME LATER
