Hi guys, I have a old 4D Maglite, now with TTS-3WCR90 (Cree XP-G2 LED Upgrade) 220 lumens. If you want to see the specs: the torch site
I have talked with the guys of the store, and he said “I’ve run the bulbs at 10 volts + using a variable DC power supply and they were fine, I think with 9.6 volts they will be OK.”
I would like to put 3x14500 cells not fully charger (aka 3,5V x battery) because now I’ve try with 2x14500 KeepPower + 2x1,3V Nihm (I know I know, better don’t do it, but I have turn on the Mag only for 10-20 sec to try if it goes). With tester it give me 10,5V.
Well, the question: do you think is a good deal buy another 2x14500 (buy from Banggood, a good deal:2PCS KeepPower 14500 800mAh 3.7v Protected, 6,99:money_mouth_face: ? It’s worth the money for lumens? Now the Mag run with 4D alkaline, so 1,5x4=6V. Running so hard at 10,5/11, will be enough powerful to justify the money spent? Because I don’t need others 14500 battery.
Thank you very much!
Shipping:
Free Shipping to United States via China Post Registered Air Mail
Delivery: 15-26 days (ships out within 7 business days)
How to customize your flashlight:
Now default we assemble 7135*8 in the flashlight,We support customization of LED tint.Pls contract with us if you want customization.And a little money will be added
I’ve read this from the specs: “Operates on a voltage range of 3.2 - 9.0V DC (brightest at 4 volts plus)”.
So, if I understand correctly, if it goes to 9V is much brigh that 3,2V. Is it right or I’m wrong?
If I’m right, if now 4D alkaline cells puts out 6V, with 9 or 10V (or 10,5 in my case with 3x14500 with adapter) will be not much brighter?
Thank you very much and sorry for silly question… :8)
