Great. So if the discussion is still open there are few questions to clarify. 1)why we need xp-l HI if we are making flooder (as stated in thread title). Are here any cons comparing to non HI version? 2)afaik 3*led reflector provides less beam artifactes comparing to 4-5…led reflectors. is that correct ? (i’m not sure where I’ve read that, here on blf, on cpf or on fonarevka). “nichia option” is for hi cri or ?
Pretty close I think, I forgot about that nice comparison by pflexpro. So using the XP-L HI could imply 20% less output and 50% more spot brightness, compared to the XP-L HD. More or less, because the comparison was not completely fair because of tint differences.
If it’s not going to be something off-the-shelf, please push for at least an attiny25 into it so it will have room for more fancy firmware. Or a 85 which costs nearly the same.
I’ve built small tube triples using 10507 optics over XP-L HI emitters. Pretty common thing to do because normal XP-L’s won’t fit under the optics without modification. For this application though, I can’t see a single benefit from using XP-L HI over XP-L HD, and there’s at least one negative — HIs are less efficient that HD emitters, so the light would be marginally dimmer.
So if we’re taking an informal poll, I prefer 219c’s to either. Yes they’re also less efficient than XP-L HD’s, but the big improvements in tint/CRI are worth it to me, plus there’s the Vf benefits. If Nichia is out and we have to go with Cree then my vote goes for XP-L HD for its increased efficiency, not to mention the added flood (which is the goal of this project, right?).
Okay, maybe I’m misunderstanding the way reflectors work. Here’s the way I see it. Please correct me if I’m wrong. I’m thinking that changing from XP-L HD to XP-L HI can be compared to adding horsepower to an engine. If you have a 50HP engine in your car, adding 10HP will not by any stretch of the imagination make it a racer. But if you already have a race car, adding 10HP can mean blowing your competition away.
Similarly, adding a XP-L HI to your SRK will by no means take away its floody beam profile, because the beam profile is mostly from the reflector. It will still be a Mega Flooder. It will just have a little bit more throw, maybe. But it won’t be a thrower by any stretch of the imagination.
If I’m wrong, then somewhere I’ve missed an important aspect of how this stuff works. So, please be kind enough to educate me.
Q6 was a temp name, like X6 based on battery size.
For now the working title is Q8 and the smaller Q4/Q5 is not under development now, first the Q8
Yes Tom E is making a list of components and the 85 will be on the first version.
But understand that for small buyers the difference between for example $0.30 and $0,90 might seem small and a no brainer, for larger orders the difference can even grow if the 0.30 item is given at a price reduction while the 0.90 could stay the same because of it being less widely used.
Then multiply that difference by a lot of individual items and things are not as close as we might expect.
Yes, the 85 is the top of my list, but we won't know how possible it is til we bounce this off of the builders for cost/availability. Also since my experimentation (from helpful tips from other BLFers) with greatly increasing the voltage divider resistors is proving to work well so far, we hopefully will go with that. Mike C has this working as well on his custom drivers.
Just fyi - our usual Momentary STAR firmware had a 0.32mA parasitic drain. Halo had a tip to cut that down - 1 liner change, resulted in cutting the parasitic drain in half -- to 0.16 mA. Using 47K and 220K voltage divider resistors instead our our standard 4.7K and 22K resistors (like in our BLF A6 and Bistro drivers for example) resulted in a 10x reduction, so now it's at 0.016 mA.
To put this in perspective:
0.32 mA will drain 1 Ah (Amp hour) from a cell in 130 days (4.3 months)
0.016 mA will drain 1 Ah (Amp hour) from a cell in 2604 days (7.1 years)
So I have 6 lights running on a ATtiny85 with these mods now. I would consider the 0.016 mA so small, it's negligible, specially in an SRK light that could have 12 Ah of power in 4 3000 mAh cells (Samsung 30Q button tops would be great, or SANYO GA button tops at 14 Ah). So, you would not have to worry bout power drainage because of the electronic switch at all. Combining that with an easy lockout feature to prevent accidental activation, will make it safer (plus a preset turbo timeout, or temperature monitoring).
For me the Nichia is not out the window.
It will be talked about with Barry!
A XPL-Hi in neatral white is however beautifully tinted.
Yeah Tom offered a view in the code (can be found on BLF) and wow the options and possibilities are awesome! Even if it must be squeezed on a A25 so much goodness remains I would buy a Q8 just for that. But let’s not get ahead of ourselves, this will all be communicated when more is clear
DBSAR is developing a lantern with the SRK as starting point, it should lead to a quality newly (chinese) produced ‘BLF-approved’ lantern.
Personally I do not see too much overlap apart from the battery compartment which (thusfar in the plans) will not be much different from the SRK battery compartment. His lantern has a different type of led, just one, different output, different UI, and it has a lantern head
