If I understand correctly, the Noctigon boards were the inspiration for the Q8’s nice thick copper PCB. It may not be red, but it’s functionally the same thing (only parallel).
It is a fat copper MCPCB in both lights. But i think that the board from the Meteor is looking a bit nicer. But the Noctigon board ( led and spring PCB) will probably cost a little bit more than the boards TF is using. But if the performance is the same (from a thermal point of view) i am happy with the TF solution.
Oh, not the Meteor’s specific PCB, but Noctigons in general. I forget where the DTP copper boards originated around here though; I think I recall Sinkpads were first?
Some earlier BLF projects used actual Noctigon boards, but since then we’ve been able to get similar items from a wider variety of sources. RMM even has his own quad boards now, which I hear good things about.
It’s not a new or unique idea, really, but it seems like DTP copper boards weren’t common in flashlights until a few years ago.
I did watch a video review of it. Produced , I believe by a member of BLF. I did consider the O-lite and Supfire (? am I remembering them correctly?) but with the Meteor priced at $130 and being so small it was a no-brainer. The others are really priced too high for me. Plus I think I’m going to like the programmability. Until the Q8 is released anyway.
I hope you don’t mind, I took screen shots of your UI 3 info so that I don’t need to try to find the info if this thread buries it. Yeah, I know, that can’t happen with the size of it and the way it grows.
Richard had them in stock so I might have it as early as Saturday. I was surprised by the numbers I saw in the review thread. I would have expected the CW version to be a hair brighter but maybe I’m missing something. The factory data shows lumens to be pretty much uniform except for one version if I remember what I saw correctly.
[history lesson] Yes, Sinkpad were the first, they started with 20mm DTP-stars and match did emitter tests of the XP-G2 and XM-L2 with those boards and the results were amazing, to the extend that match disappointedly stopped modding because they performed just as well as his custom carefully machined massive copper led-mounts. Flashlight performance became too easy!
Then we wanted 16mm and PilotPTK designed a board for Sinkpad that could also be trimmed to 14mm and 12mm, and there was a group buy for them. Still Sinkpads 16mm boards have that weird design while 14/12mm is now hardly used by anyone. The 10mm Sinkpad came much later. [/history lesson]
Yes, that wouldn’t surprise me at all if they do. I assumed that it was going to become “obsolete” due to other lights coming out, hence the price reduction (there has to be a reason). I use the word obsolete, but a newer light won’t make it any less bright or make the light larger. It just won’t be the newest light available. That doesn’t bother me. I still use C8s and how old is that design?
Another light similar to the Q8 will be the Utorch UT03. It has 3 xhp70. It’s priced competitively at $xx, but lacks the cool ramping firmware of the Q8. Who knows when it will be released, though. The Q8 might be out first.
I may look similar but it will have a way different beam. I have a X7 Marauder with 3xXHP70 leds and it is pure flood, while the Q8 with its hard driven XP-L leds actually covers some distance.
