the ramping mode works great but the blinkies not i double click from off to turbo then double click to strobe and if i click once again its off iff i make a fast double click i get to bike strobe but from there i cant get any further blinkies single click turns the light off and double click also off ā¦. and the double click has to be very fast
Great seeing a lot of new arrivals that bring a lot of ābong for the buckā
Li ion and bang are a poor combination
After the one yesterday that was a setting thing we now see the 4th issue
Can you make a video while it still is in flicker mode and has not stopped completely (yet)?
And pitches help of course.
Maybe some testing with a DMM?
Thanks for letting know and still be able to enjoy the rest of the Q8!
Title changed and OP updated with an announcement;
Dear all,
It is clear there is an issue with some lighted switches.
I have a little sad announcement to make, production of new Q8 lights is halted while the problem is solved.
There are 2000 hosts ready for assembly and all the parts needed are there.
Thorfire is contacting the supplier of the SMD LEDs and all pictures and tests people do with a non working lighted switch assembly help to further pinpoint the reason of failure.
So I am very sorry to say we are back at āit is done when it is doneā but with a big difference, before we did not have a problem if answers took days or even weeks, now that everybody has literally invested at least $40,- we want things to go fast and Thorfire is very responsive so there is good cooperation to get it done ASAP.
This also means that if you have not received a shipping notice, it will not come before it has been made clear the problems are solved.
I have confidence in Thorfire, the issues (now 4) came after some use, all Q8 lights work out of the box so that is great.
With 4 problems more are expected so this is the best way to proceed IMHO.
I am really sorry that the wait continues and hope you can accept it.
Also keep problem reports coming, we will find a good solution while aiming at having the rest free of the issue.
Turns out it is the resistor. After swapping to another smd led i had from a battery back circuit board (getting polarity right on those things is a pain in the arse), it was still flickering. I re-applied heat to the resistor and noticed that when the iron jumped the resistor (touched both sides) both switch leds came on really bright. So i stacked another smd resistor on top of the original and BAM! Solid light. Measured current draw 6.6mA so you do the math on what the equivalent resistance is, Iām too tired and can go to sleep happy that we found a fix.
How do you disassemble the switch? I got the 2 screws out from the driver board but then the wires are fairly short to really see anything else. Iām hoping someone can do a detailed breakdown of the flashlight for modding. Iād like to swap out the green LEDs for something different. Perhaps pink and blue?
Once you can get past that first blinky, into the 2ND or higher, you press and hold to go back a level and can then click to go forward again if you wish. See my video. I think itās Narsil Part 2.
So it wasnāt a bad solder of the resistor, it was the resistor itself? Maybe 15k is too high a resistance?
6.6mA is a big drain. I get 0.40 mA at 8 volts for my lights.
The Q8 runs at half that voltage and draws 0.14mA.
So if the Q8 resistor is 15k, then maybe reduce it to 12k or 8k might be enough to keep it working and still keep the drain low.
Itās quite possible the 15k resistor is dropping the voltage too low for the smd leds to light up.
Or Thorfire might be able to switch to LEDs that run at a lower voltage and keep the 15k resistor. This should reduce brightness as well.
I got a small assortment of leds from DBCustom. Iāve got a bright green and a weak green. TF are definitely using a bright green. Maybe a switch to a weak green would work better?
We donāt need a switch light that is so bright. Do we?
Iām thinking that the tolerance of the resistor might be too large, and the LEDās are not reaching the Vf needed to function reliably. I made sure to melt the solder on the resistor before, and it didnāt fix it. I will try and find a better solution in the spare parts i have.
Sorry I donĀ“t get it - so itĀ“s a production fault and ALL lights already shipped are generally affected because the wrong resistor was used in production? So those people receiving working lights can expect the switch led/circuit to fail sooner or later? Or am I āsafeā if my light works properly during the letĀ“s say first few hours of use?
the ramping is great maybe the greatest in any flashlight i ever had
but the blinkies the opposite strobe is ok bkie flasher also ok police strobe also ok but the beacons are slow blinkers not real lacation beacons liek on a nitecore and the acessability is very hard to get to where you want to be its hit and miss for me
Recād mine today, AND I LOVE IT!!! This is the most fun I have had with a life in years! It is really easy to accidentally tell the green led to stay off, but only because of operator error. I canāt wait for the second light to show up! Thank you The Miller and Tom and the entire design team-this is a jewel of a light! Pictures coming soonā¦
well it is impossible and unwise for me to state things about āALLā lights.
So you canāt expect that
we do know for sure that 4 of the arrived Q8 lights have an issue with the lighted switch and the rest of them do not.
We do know that the not working switch light do not affect the use of the Q8
And now more information on the issue is being reported this gives Thorfires engineers more to work with.
So just enjoy your Q8 and if the issue presents itself, let us know here. All videos and pictures are helpful and much appreciated
Your jumping to a few wrong conclusions here. First of all, it may not be the wrong resistor. You see, the switch leds and the resistor have to work together. The leds are typically only made to run between a certain voltage range. Letās sat 2.2v and 3.4v just for example. So we use a resistor to drop the voltage down from 4.2v to somewhere below 3.4v. What is most likely happened is TF sourced in some new leds and their specs may have been different. If you recall, some people have two different brightness leds. Since they are wired in parallel (getting the same voltage) that means the 2 leds are not the same.
One might be made to work from 2.2v to 3.4v and the other from 2.4 volt to 3.6v. The early leds might have been the 2.2-3.4 leds and the 15k resistor worked fine by dropping voltage down to 2.3v.
Then when you mix in this other led, it canāt run below 2.4v so it turns off when feed 2.3v.
This is just an example, but I hope it makes sense.
We donāt know if all Q8 switch lights will go out or be fine because we donāt know which leds were used. Itās still too early for definitive answers. Letās be patient and let the Miller sort this out.
If this were the case, it would explain the flickering and eventual failing of the led as the cell voltages drop, but also it would happen first on high output levels, then recover as the load drops on lower levels and the voltage picks up. The problem would disappear when the cells were recharged again, and could be diagnosed properly by running the light on a bench power supply and measuring across the led.
Anyone tried that yet, even recharged their cells to see what happens at 4+V?
