Another thought/observation if the o-ring was mistakenly installed forward of the proper groove (see my o-ring closeup pic) That would prevent full threading the battery tube on. As the o-ring would bottom out on the top of the internal head threads.
Hey, mine fits very tightly… I thought I had a problem at first, same behavior… I applied a tiny bit of lube to the o-ring and the inside of the head just before the threads. That took care of it! The tolerances are very good on this light, at least my sample.
Gotta say, this thing is awesome! I got to spend some time in the country with it and compared it to the X7R. The X7R is brighter, but this is focused so well that it is visible in the center of the X7R beam at 120 yards! Also, has much better tint than the X7R.
Ha ha, there’s actually a little more tolerance due to the inside of head diameter (smooth, non threaded part) being 50mm and the outter diameter of the raised rib (just above the o-ring) equals 49.52mm.
Wow 71 new posts, that must mean something bad or good, bad this time.
70mm length is not too long.
The Panasonic protected cells work and are even longer (and they work fine, not a real noticeable difference compared to 30Qs for example (to answer the question about it ) )
So if cells are charged , work in other lights , have a button top there should not be a problem.
Good it works without oring.
Now can you lube the oring and place it in the correct lowest slot?
Just got mine yesterday. The switch indicator light went out within 20 min but doesn’t bother me. Otherwise seems perfect. It really hits the nail on the head with tint and beam profile imho.
