Thanks for the info. I was asking as I am seeing quite different lumen figures to those in the listing, and thus I was interested to know the approx % output instead of lumens (which I assume would be for batch 1, with unspecified batteries, voltage and/or time after turning on). It seems odd that the approx. % is shown for all mode groups in the manual apart from the two BLF A6 mode groups.
Sorry, I really haven't given the mode sets much attention. I didn't give the BLF A6 modes a % rating because they were not defined by %, but rather a smooth scaling, with the levels defined by an algorithm TK used, I believe. Not sure they would work the same as in an A6 because the A6 was based maybe on a 1500 lumen max while the Q8 is more like 5500 lumens.
Jason, David asked me a couple pages back about the coffee I used to drink. I get fresh roasted coffee beans from Ethiopia and Panama and grind it fresh every day. Delicious! Kid I ain’t and Starbucks doesn’t know me at all. I spent 20 yrs drinking the muck they made at the lumber yard, time for the good stuff!
I used my Q8 out and about tonight, amazed my brother and just in general lit up the night. Works great, the lit switch button can really come in handy out in the night, easy to lose a light out in the open if you set it down and get moved away from it doing things. Not with the switch glowing!
My Q8 arrived last night and all i have to say is …
YOU GITS HAVE RUINED ALL OTHER LIGHTS FOR ME !!
I think Narsil ramping should be mandatory on all other lights from now on !
Off I go to trip all the light circuit breakers at work ….
Seriously, this is an amazing light and I look forward to using it as much as possible - huge thankyous and kudos to everyone involved
Yes it is true
Use a clicky Bistro light or e switch Barsil and it pretty much retires the ones that don’t have it.
Only thing that amazes me is that manufacturers choose not to go for it.
Yes the drivers are little more expensive to make but it seems so worth it.
Yeah, I usually like to “play around” with new lights when they arrive, check out all the features and such. I haven’t made any changes to my Q8. I haven’t even entered configuration mode yet. The ramping is so sweet!
I can second the burr grinder. But I rarely use my French press any more. I did use it last weekend while camping, though. I had to get up early to start the fire to heat the water to make my coffee.
