Some interesting data now that I have a sphere that can read lights this high.
I have two 5x SRK’s that came with XM-L2’s (only 2 that did besides the 3 I have for sale here out of the ~60 ordered). Normal cool tint and really low flux.
Both lights are otherwise identical except that I de-domed 1 of them.
Here are some numbers:
Normal XM-L2
Lumens = 3900
Kcd = 35k
Throw = 370m
De-domed SRK:
Lumens = 3600
KCD = 70k
Throw = 525m
So a loss of less then 10% lumens for a doubling of the intensity. This is pretty well known by most already but I can say that the beam profile on the de-domed light is much much more useful in day to day use (tint, not so much but then neither of the tints is pleasing to look at).
You have an actual hot spot with the de-dome and can actually see more then 100 feet before you are blinded by the spill. Yet it puts out more then enough light to light up everything around you easily. Inside the rebound light more then lights up everything.
Plus to the human eye the de-domed light easily looks much brighter. Showing it to a few people today they all thought the de-domed version was the brighter light by a significant margin (although they were not the biggest fan of the tint shift from the dedome, while not great it is tolerable).
On another note I actually just put together a 4x SRK with XP-L HI’s and discovered something interesting about the reflectors.
After putting it together I noticed that the hot spot was not any smaller then the 5x de-dome, in fact it looks slightly larger. I know it is focused properly as I printed up some centering rings from between .75mm and 1.25mm to get it just right.
So I started looking at the reflectors and the 4x reflectors have a flat bottom around the LED while the 5x taper all the way to the LED base. I have noticed the same thing with tube light reflectors, the ones that taper in smaller at the bottom throw better.
So I like that the CAD drawing show the Q8 will also be tapered all the way to the LED as well.
So the point of all that? I would love to see an XP-L HI offered in this light, or even some High CRI XP-G3’s but that is also what modding is for.
I know it was mentioned before but a host version being part of the plan would be real nice for those that want to do other things with the light then the XP-L.
