Hello again!
For some time, I have tried to find a replacement for my Solarforce L2T.
In service at work from maybe 2011-2012 (after L2m).
This is it:
https://www.solarforceflashlight-sales.com/products/solarforce-l2t-full-stainless-steel-belt-clip-black-forward-clicky-flashlight-body
(beat up pics I will take later)
I have added SS bezel ring, it turns out the head de-forms less in impacts when it has it.
Running it on XM-L2 dropin, neutral tint with a good programmable driver. Puts out maybe 600-800lm?
So, why is it so hard to replace, you might rightfully ask?
After all, it is so old model…
Known drawbacks are at least
- Bad heat dissipation from dropin
- Overall size and weight not the smallest
- Throw capability poor + deep head/bezel limits spill/flood
- no internal charging or anything fancy stuff like in todays flashlights…
But why is it, that I still stick with it?
I have not yet spotted (there may be, hopefully) a light that combines such good form factor:
- The tactical protruding switch at back is a MUST, I operate it 100% of time with leather gloves on
- 18650 size is a must because of runtime
- Aggressive clip that “picks fabric up” over the width of the flashlights head is extremely useful. I pick it up and side-pocket it tens of times in a day.
- Ability to replace broken parts. At least Head and Bezel ring have been replaced among one lens I think.
- I need throw 10-20m at MAX (30-60feet) so thrower is not in search. I even use Diffuser in this often.
- Big clip enables it to be used even as a headlamp with Peltor Active headset.
- It really takes the beating well…
- The “Cigar-Hold” is damn GREAT!!!
The replacement, if I ever find one, needs have most of these.
I understand I cannot find legoable lights other than Solarforce.
I don´t care about heat dissipation (seriously!), I use it on MAX 95% of time BUT I use it only for 5-10secs.
Modes are needed for occasional repair work and in headlamp use.
No need for super-powerful ones, under 1000lm is well enough for close range. It wont hurt though.
PWM is a big NO-NO as is cool tint.
Protruding switch is almost a MUST, as is a good strong clip.
Head of the light cannot be much larger, otherwise it will hardly fit to my dedicated pocket ![]()
What I have found up to date:
Olight S80
They got this for me at work.
Too throwy, too cool tint.
Worst things are missing clip, terrible to operate gloves on (small switch) and too bulky to carry.
Switch boot gave up in no time, second light now there.
Convoy C8
- recessed switch…
- Head too bulky for proper pocketing
- clipping issues….
Jetbeam E10R
- Just lacks the runtime and as far as I remember, has PWM
- Very light, you can drop it without noticing
- small, not the most convenient to use with gloves…
- Turned accidentally ON in pocket several times
Convoy EDC series
- Otherwise quite nice but they have recessed switch
This COULD be very good:
…but it appears to have PWM even on HIGH and the strobe is super-easy to push on accidentally. Cool tint etc…
Or these:
But I´m not so sure about the clip and operating side switch with gloves.
I will anyway give it a test, order it and have a try.
So.
What are Your suggestions, dear enthusiasts? :sunglasses:
I have probably missed some Gem that is already here?
Point me out, please ![]()
