In this 12 volt , 2.5A wall adapter that broke, I replaced a 16v 680uf low esr and a 16v 1000uf low esr with two normal 16v 1000uf capacitors.
The led works again and I measured 12V coming out of the wall adapter.
I used normal black 105c capacitors from ebay, no low esr.
So I know it works but is it safe??
Both broken caps were buldged and leaking.
Well, not much explicit info provided Buzzing Bulb. Like some nice board shots, I mean. ;-)
The stuff is probably working fine with the fix you performed. Saw your message a few hours ago but I had to sleep some (not yet finished :-D ). You really pulled the trigger fast.
The standard esr capacitor may do fine as it is for the supply's remaining life. Pics and advice from an electronics expert may comfirm this.
Is the circuit board discolored under the big diode on the upper right side behind the caps—that looks like a heat-affected area, and temperature will affect the life of caps and other components.
The caps will work just as well as the old ones for this application.
If you want to extend life and add margin then go to a higher voltage rating, e.g. 20 or 35 V.
A 16V cap in a 12V power supply is not enough margin in my opinion, i prefer at least 2x margin on voltage.
The biggest killer for caps is the heat due to the ripple currents. Can’t tell what is controlling the switching frequency, but at 50 Hz a 1000uF cap looks like a 3 Ohm resistor which will be much greater than the ESR whether low or normal.
It looks like an optocoupler ic—what’s the part numbers of any chips?
Nice observation kennybobby. If the diode is heating up too much it is indeed being overstressed. It would be a wise idea to replace it with a higher current rating one, twice at least I'd say. That would also result in lesser heat dissipation at it, something good for the nearby capacitor.
Put a 20A diode there and it'll outlast 4th World War. :-D
My diode replacement advice wasn't meant to be random, but to minimize heat stress damage. For example, replacing an overheating SS34 with an SS54 should yield an improvement since the higher current diode will drop slightly less Vf and its thermal resistance is also lower, thus improving (reducing) operating temperature.
Doesn't matter how "big" the diode is.., the quantity of heat will be the same , except the case when you'll find a Schottky diode with a lower voltage drop at the required current ! A small heat sink on this will help a lot ...
Kennybobby is right , higher voltage on capacitors will extend the life ( most of the time , bigger the voltage , lower the ESR ...)
Size does matter Adrian, be it for bad or good. The higher specced diode will display a lesser voltage drop at the operating current, so less heat is dissipated; then, both the higher mass and surface of the bigger unit will result in an overall reduced temperature (lesser hotspot effect).
A hot SS34 can be replaced with a massive 20SQ45 for an staggering improvement in diode temperature. For as long as the reverse instantaneous current not being an issue, that is.
