After reading this thread I started thinking about doing a direct drive light or two. This should be about as simple as it gets, source, load and switch right? Then I started thinking about the possible pitfalls, destroyed LEDs, destroyed batteries and the possibility of holding a hand grenade in my hand.
I’ve ordered various parts I didn’t already have on hand but thought maybe I should ask a few questions before I start.
The likely candidates are:
1. My current L2P, triple XP-G2 mounted on a copper heatsink with a 7135 x 14 driver. It currently pulls over 5.0A with no evidence of excessive heat (it does get hot though
The only thing I’m thinking of doing on this other than swapping the driver for a contact board is changing the MCPCB from aluminum to copper.
2. My current M1, dedomed XM-L2 on noctigon with a 7135 x 12. Thinking just swap the driver for contact board.
3. My current L2M, XP-G2 on noctigon with a 7135 x 12. Again, thinking about swapping the driver for contact board but not sure if the XP-G2 will handle it.
4. An empty M1, ordered an MT-G2 and two AW 18350 IMRs, I also have AW 16340 IMRs and ICR123s available.
5. An empty UltraFire WF-602C using an XM-L2 on noctigon with either a 16340 IMR or ICR123.
These would be simple WOW lights, no intention of running for more than a few minutes. I have AW IMR 18650s and an assortment of protected AW and Panasonic 18650 batteries handy.
Questions that come to mind:
Are these combinations feasible?
Can a single XP-G2 survive direct drive in a P60 host?
What size wire should I use? I have silicone available in AWG20, 22 and 24.
Should I avoid the usual spring, resistance mods?
Am I really going to gain much in output on the first two lights?
I already have two of the fifth lights (WF-602C) with XM-L2s (dedomed 1C with a smo reflector and the other 7D4 op reflector) with 7135 x 8 drivers. Would I see any increase by going DD?
Thanks for any suggestions.
