I am no battery-expert and not really into flashlight measurements (ok, a little), I am messing with my smaller flashlights (I do not own any of those high power throwers) and a lux-meter (which is not calibrated, but gives very consistent readings) and I have a few questions that hopefully one of you with a bit more experience than I can answer:
I am trying to do a measurement of the OTF lumens of my flashlights. I do not have a IS, so to do this I use the ceiling bounce lux-reading that is often done instead, and relate this to a flashlight with known output. In my case this is the Thrunite Ti (stated as 60 OTF lumens on a fresh Duracell alkaline).
Question 1: how far am I wrong when I calculate the output in lumens of my flashlights like this? Is it less than 10% (which is very ok to me), or is there anything much more unreliable about this method that I don't know of?
Assuming that the OTF-output measurements are reasonably correct like this, I combined this with the tailcap current draw of the lights, and assumed that a freshly charged Li-ion keeps at about 4V under load (also at more than 2A) and a fresh alkaline 1.5V (ok, I could have measured that, but, well, I didn't), in this way I calculated the OTFlumens/watt of the lights.
Question 2: Do I assume correctly that the voltage of fresh batteries are maintained well under load (of say 2A).
The OTFlumens/watt figures I came up with are quite sobering I am afraid, most of my lights (most are cheap and modded
) calculate round 40 lumens/watt, the best one actually is the Thrunite Ti on alkaline with 55 lumens/watt.
Question 3: Are these figures remotely consistent with measurements done by others? I did a (ok, quick) search and I was not able to find a complete set of measurents on any light to do the calculation (that is OTFlumens together with battery current draw/voltage measurements)
Lots of questions, hoping for answers
. And into the world of educated guesses I am afraid. Still curious about the questions though...
