I have another couple of dead Ridgid 18V packs that I would like to repair. I have already replaced the 3 cells in a bad 12V Ridgid pack that had Chinese cells.
This time the Ridgid packs have quality cells, They are 18V, 10 cells packs that have 5 pairs of 2 18650’s in parallel for twice the capacity. Somewhere I read recently, I can’t find where, that it is common for the first cell in the serial chain to discharge during standby. Once they are run down, they are damaged. It must be true because both of the 18V packs have dead cells, first ones in the chain. All other cells are sitting at 4+ volts.
Now on to my questions.
The other day, at Home Depot, I did what I often do. I checked in the Li-ion recycle bin that they have next to returns. I am constantly looking for Li-ion packs to salvage cells for these 2 that I have. Of all the packs I see, I would have to say that 95% are the 18V Ryobi NiCad packs. Those are the worst ever. I have maybe 10 and they are all shot. Anyway I found an 18V Makita that physically looked pretty good on the outside, so I grabbed it.
It was easy to open and inside were 5 of these.
Trouble was that when I measured the voltage across each one, they all came in at between 0.35 and 0.40 volts. My heart sank, but what the heck, I threw one on the charger and after about 5 minutes it was up to 2.5v. I took it off and let it rest and about an hour it was still holding the charge. So I tried each of the other 4 and got them all up to 2.5. All seems well and good, so I charged them all up to 4.15v. I measured them again, warm off the charger and put them aside for 18 hours. The next day I re-checked the voltages fully expecting to see a big loss in voltage, but no, they only lost 0.02v each!
So by now I’m thinking maybe these cells are going to be ok? I ran them thru the only real world benchmark I have, my FandyFire Warrior. It has a built in charge gauge that I can use to give me a good “feel” for the cells. For instance, 3 brand new UltraFire “3000” mAh cells only run for about 40 seconds before the charge indicator drops 1 peg. Total crap cells. The Panasonic true 3400 mAh cells will run for longer than I care to wait (more than 30 minutes) These cells, from this pull, even though they went thru such abuse and were discharged down to 0.35V, run for about 15 minutes before the indicator lights drop a peg. This in spite of these cells being only 1300 mAh high discharge cells in the first place.
The question is, could it be possible that these cells are going to be OK?
Do the cells in Li-ion packs more forgiving to severe discharging?
I am planning on using 4 of the 5 to repair the 2 18V Ridid packs I have.
BTW, each of the 2 Rigid packs have different cells in them. One came with Samsung cells and the other had Sanyos.
