It’s been some time since I have raised any money for Justin/Val. I did have plans to sell off some OL knives with additional items but I was/am waiting on some stuff to be delivered. It is one of the main reasons for the delay. I’m in dispute with the vendor I purchased the additional items from. I have felt a little guilty for not being as proactive since Justin’s passing but here is something for the meantime.
For those that are not familiar – the funds for this will go to Old-Lumens (now Mrs Old-Lumens). Please read this thread for more info.
RULES
Cost – $3 per ticket or $5 for 2.
Anyone can enter. Anyone can enter as many times as they like. To enter please submit money to pinkpanda3310 (at) gmail.com and post in this thread that you have done so e.g. “entered” or “paid” or “pick me big bird, pick me” etc… Please note in the paypal what your forum name is. End time for this raffle shall be Tuesday 21st March at 00:01am UTC. Sometime that day I will use random(dot)org to pick 5 winners.
PRIZES
Light 1
SRK with photography lens hoods and KD 86mm reflector. I think it’s an xpg-2 led not sure exactly, come to think of it, it might not be. I’ve had this host for a few years. Fitted a copper shelf before I had a lathe. Then when I did get the lathe I think I was cutting in a recess for the led star in the shelf and it slipped in the lathe jaws so it has scratches on the head. The lux is not high, from memory I measured 350kcd. I’m no longer interested in tweaking it, honestly I’m not sorry to see this one go. UI is high-low STAR firmware
Light 2
Multifunction bikelight. I machined copper pills and fitted xpl hi leds and LD1 drivers. Yes 2 drivers, one each side, as a result it can be a PITA installing the batteries. I’ll try explain why - the drivers work independently of each other. They share the (-) and the mom switch but not the (+). The drivers work with both tail and side switches so when installing the batteries the driver in front of the cell activates (turns on). When installing the second battery it is important to leave the first side on AND make sure they are in the same mode when the tail is screwed on. Fumbling the tail cap can change the mode of that driver. Once installed and the drivers are in the same mode it generally stays that way. I have intentionally clicked the button quickly to see if they go out of sequence and yes they do. In general use I haven’t had a problem though. Roughly 5000k tint. This one also has a scratch near the switch.
Light 3
DQG with 4p xhp-35. Driver has turbo resistor bridged. I think the driver strains a bit to boost up to xhp-35 levels of voltage because in mid mode it seems to have a dim flicker. It’s not terrible but noticeable. I didn’t notice it in other modes. Tint is around 4000k. Probably has scratches on it somewhere…
Light 4
uf-2100 body with 502b head and sportac triple P60. I like the shape of this thing. I had intentions to change out the driver but never got to it.
Light 5
Supfire L5 with xhp-70 and fet driver. high-mid-low on STAR firmware. Frosted reflector and I haven’t centred the led exactly to try and reduce the donut hole. In outside use the hole is hardly noticeable but you’ll see it white wall hunting. Runs on 2x 26350 cells. I realize not everyone has these cells so I’ll check what Auspost’s restrictions are for sending batteries nowadays and try to include them in the package.
Money raised – $160
Entry List
1 – 10 (low #’s don’t win apparently)
11 The Miller
12 The Miller
13 The Miller
14 The Miller
15 Ford Perfect
16 Ford Perfect
17 ImA4Wheelr
18 ImA4Wheelr
19 M78
20 M78
21 apt323
22 apt323
23 apt323
24 apt323
25 powerfultorches
26 powerfultorches
27 chooma
28 chooma
29 Petroleum lantern man
30 Petroleum lantern man
31 Old bolt
32 Old bolt
33 Old bolt
34 Old bolt
35 Old bolt
36 Old bolt
37 Old bolt
38 Old bolt
39 vwpieces
40 vwpieces
41 vwpieces
42 vwpieces
43 MRsDNF
44 MRsDNF
45 MRsDNF
46 MRsDNF
47 LumenHound
48 LumenHound
49 LumenHound
50 LumenHound
51 LumenHound
52 LumenHound
53 LumenHound
54 LumenHound
55 The Miller
56 The Miller
57 yasenf
58 yasenf
59 yasenf
60 yasenf
61 The Miller
62 The Miller
63 Longmire
64 Longmire
65 vwpieces
66 vwpieces
67 vwpieces
68 vwpieces
69 Lopan
70 Lopan
71 Lopan
72 Lopan
73 djburkes
74 djburkes
Good luck everyone ![]()
WINNERS PICKED
Winner #1 - Lumenhound
Prize #1 - SRK thrower
Winner #2 - The Miller
Prize #2 - Multifunction bikelight
Winner #3 - apt323
Prize #3 - DQG quad xhp-35
Winner #4 - apt323 again
Prize #4 - P60 lego
Winner #5 - Old bolt
Prize #5 - Supfire L5
Congratulations to all the winners and thank you to everyone else for your support. ![]()
