when I publish that , I will make a review on BLF , you can wait
RD6006 review
if you don't have so much space for S06A case, you can choose S06D to get a compact design, you can even use battery pack as input to get a mobile power supply
RD6006 feedback
exquisite, good quality, perfect if it can be replaced with a metal panel, the voltage and current are very accurate, PC software is easy to operate, it is a satisfactory shopping. Thank you seller!(hello, metal panel you can search 100MHz)
http://aliexpress.com/item/4000282551930.html
RD6006 Review
Super! It works clearly. It lies a little in voltage, and the higher the more. But not critical
(the output is not exact equal to the vlaue you set, floats within a certain range, you can check the output accuracy at the technical parameters)
China customer review
the ripple is acceptable, and the size is not too large
RD6006 review
Got a module well packaged in a foam box. Everything is as described. I really liked the module. Good seller shipped quickly.
RD6006 feedback:
More than recommended. Excellent seller, shipping and receiving. I already assembled it and it works perfect.I bought it on day 3 and received it on day 14. Super fast.
RD6006 feedback
I really liked this power supply, it gave 20 volts from the old charging for the laptop to the input. The box from the device can also be a temporary housing.
(be careful about the heat dissipation)
RD6006 feedback
The hifi 500w 60v switching power supply with dynamic load control became excellent in a small case. It has an output for powering the fan controller.
RD6006 feedback
Excellent! Very well packed. Package not damaged. Goods exactly as described. Verified, working as expected. Recommend.
