RD6012 Released
Hello, everyone, how are you recently?
we release the second power supply of RD series, it is RD6012, 60V, 12A, 720W power supply, we redesign the circuit, compared with RD6006(60V,6A,360W), it has higher current output.
because the new product promotion ends now, so the price returned to normal standard
Here is the product link:
RD6012($63.5)/RD6012W($67.5)(some area may have extra shipping fee):
https://www.aliexpress.com/item/4001053200176.html
S12A/S12D/switch power supply:
https://www.aliexpress.com/item/4001068050317.html
if you don't know what RD6006 is , you can have a look at this topic:
https://budgetlightforum.com/t/-/59055
You can also have a look at the product video, assembly video and actual test video on YouTube:
basic introduction:
case assembly:
actual test:
RD series share the same PC software and same APP(APP has been updated to a new version, more functions)
of course they have same functions and same operation ways, so it is still so easy to use
here is the comparison chart (RD6012 and RD6006)
Model |
RD6006 |
RD6006-W |
RD6012 |
RD6012-W |
Input voltage range |
6-70.00V |
Output voltage range |
0-60.00V |
Output current range |
0-6.000A |
0-12.00A |
Output power range |
0-360W |
0-720W |
Input voltage measurement resolution |
0.01V |
Output voltage setting measurement resolution |
0.01V |
Output current setting measurement resolution |
0.001A |
0.01A |
Battery voltage measurement resolution |
0.01V |
Input voltage measurement accuracy |
±(1%+5 digits) |
Output voltage accuracy between setting and measurement |
±(0.3%+3 digits) |
Output current accuracy between setting and measurement |
±(0.5%+5 digits) |
Battery voltage measurement accuracy |
±(0.5%+3 digits) |
Automatic cut off current value when charging |
10mA |
100mA |
Output ripple typical |
100mV VPP |
250mV VPP@6A |
Working temperature range |
-10℃~40℃ |
External sensor Temperature detection range: |
-10℃~100℃/0℉~200℉ |
External sensor Temperature detection accuracy: |
±3℃/±6℉ |
Constant voltage mode response time |
2ms(0.1A-5A Load) |
2ms(0.1A-5A Load) |
Constant voltage mode load regulation |
±(0.1%+2 digits) |
Constant current mode load regulation |
±(0.1%+3 digits) |
Capacity measurement range |
0-9999.99Ah |
Energy measurement range |
0-9999.99Wh |
Capacity and energy statistical error |
±2% |
Buck working mode |
Voltage drop >1V and >10% |
Cooling fan start condition |
Output voltage>40V or Output current>4A or System temperature>45℃ |
Output current>8A or System temperature>45℃ |
Cooling fan shut down condition when working |
Output voltage <40V and Output current <3.9A and System temperature <45℃ |
Output current <7.9A and System temperature <45℃ |
Over temperature protection |
System temperature >80℃ |
Screen brightness setting |
0-5(6 level in total) |
Screen |
2.4 inch color HD display |
Weight(with package) |
About 607g |
About 642g |
Product dimension |
167*81*65mm |
Support USB communication |
yes |
Support WiFi communication |
No |
yes |
No |
yes |
