I am looking for rechargeable C size NiMH batteries and a charger. Just had a baby and a lot of the things for the bassinet and rocking seats use C batteries and I would like to get some rechargeable ones so we aren’t making so much waste. If anyone has any recommendations I’d appreciate it.
I recently went through asking for a C cell recommendation. Did not get a whole lot of usable information.
I have have had 8 Tenergy cells for several years with light use. One cell has failed. I have ordered 5 cells to replace one set of Tenergy. Which means I now have 3 spares for the 4 cell Tenergy use.
I could not find a whole lot of C NiMh tests. Most were for D and AA.
What I did. I went through several lists of cell tests. I made a list of the top performing performing D and AA cells. Ds ran between 7700 mAh and 9500 mAh. The AAs 2000 mAh to 2600 mAh.I then went through the list that had a D and an AA test. The intent was to see if the quality of a brand was consistent across battery sizes. Eliminating batteries without tested sets. I also checked if they were LSD. With your baby stuff use, that may not be important to you.
The best choice (in my opinion) I found is Soshine. 9300 mAh on D and 2600 mAh for AA. It shows a constancy in manufacturing.
Amazon Basic cells (1900) were the low end of my AA list and EBL (7700) on my D list. In the AAs without a D test, these are the best overall capacity. PowerX (2600), Imedion (2700), and Tecxus (2600). These would have been contenders if I had found D cell numbers or a C cell number. Try to find D tests that pair with the AA tests and you may have a good alternative.
A note of warning on cells. A number of manufacturers do not actually make C and D NiMh cells. They take a C or D shell and stick in an AA or 2. There are no C Eneloops.
Clearly this is not an exhaustive technical evaluation. I just got tired of trying to find all of the potentially useful cells. I just wanted to get batteries.
When I get the cells, and my charger can provide some information, I will add that to this thread.
Putting panasonic sub-c cells in a diy c holder?
https://eu.nkon.nl/rechargeable/other/panasonic-sub-c.html
Less capacity than regular c cells, but higher quality.
I just noticed today that PKCell has some pre-charged (so I assume low self discharge) C and D NiMH cells for sale. Spendy things though, ~$9/cell.
Soshine c cells no longer appear to be available.
I bought 8 C EBL 5000 mAh low self discharge cells from an ebay vendor. From the time to delivery I believe they are in the US. They present themselves as EBL.
Tested 2 cells 3 times on an Lii 500 charger. Then 2 more for a single test. They are coming up as 3500 mAh cells.
I am awaiting a response from the vendor. .
Tenergy seems to get very good marks and they have three D/C lines: the premiums, the Centuras and the basic (blue wrapped versions.) Stick with the premiums, or the Centuras, which are quasi-low self discharge offerings, but they don’t have quite the capacity of the premiums.
Chris
Tenergy is the cells I have had failures with. I looked into them again. Amazon reviews show about 30% failures. This is harder than I anticipated. I have not found much in the way of good testing on C cells.
Which Tenergy? I’ve had personal poor results from the blue ones in both AA and D.
I’ve been trying the Centura C for about a year+. Certainly not Eneloops but they’ve been doing OK. Losing capacity faster than I’d like but not nose diving like the blues.
FWIW I have some Tenergy Platinum 5000 Sub-C out of a RC power pack that got a couple hundred cycles over 3 years in a dive light before one cell died. The remaining cells tested out @ ~ 3600-3800 after that use and with a couple magnets on top for spacer/adapters have been used in the same light as the Tenergy Centura, and done just as well. Eneloops in a C-adapter do not do nearly as well. The light is pretty inefficient but well suited to my purpose so I keep using it. It’s easy to take down and recharge.
If you believe the math from discharge tests of that same pack when new the individual cells were ~4800. I don’t think they stayed that way long but I did not do regular testing.
I also have the Tenergy centura cells. Two of them have failed. They were not used very much. I have a set of 8. The device they are in uses 4 so I have a rotation available. I don’t want to mix new and old cells, so I started my quest for C cells.
I have also tried Eneloops in C-adapters and was not happy. It is also a pain to recharge 12 cells instead of 4.
One of the new EBL cells showed almost 4000 mAh on the first test. It was one of the cells I tested three times. Figured they would improve after a few cycles. Neither of them ever got above 3500 on the subsequent test runs. I ran a second pair of the EBLs through one test cycle. Both < 3500.
I don’t know if these are fakes or not. The ebay site seems to imply they are actually associated with EBL in some fashion.
But these cells are clearly a fraud. If it says 5000 on the cell; it needs to be 5000. And they are advertised widely. And always at 5000 mAh.
It is like buying a quart of milk and find out when you get it home, there is only a pint in the container when you put milk in your cereal.
A few months ago I bought a pair of these: https://www.ebay.com/itm/2-x-everActive-C-Size-Rechargeable-batteries-Silver-Line-1-2V-min-3000mAh-Ni-MH/112771103088
Not bad low self discharge.
Idk about you, but in my alphabet the letters ‘C’ and ‘D’ are in two different places ![]()
Of course, but the tests can provide an idea of the sort of actual performance versus rating figures the given brand cells may provide.
Cheers :-)
IMR Batteries has the Soshine C and D nimh on sale/clearance right now.
The batteries are cheap but shipping is not.
I bought some of each.
I’ve tested a few of the Cs on my Opus BT-C3100 and am getting ~4.6 AHr. This is with 700mA discharge rate.
This falls in line with “Torch the Battery Boy’s” testing of the D size: ~80-85% of rated. I’m sure they would be a little higher at 200mA discharge.
So decent. If they are reasonably low self discharge rate, I’ll be happy.
FB
FBsLights - I see what you mean about shipping. Almost more expensive than the batteries. Thanks for the heads up. I ordered 12 cells. The reason they are so cheap I suspect is they are no longer being sold in the US. Maybe out of that business altogether. They still seem to have a whole bunch of different batteries on the market.
Barkuti - That is what I did before. Went for C’s that were in a product line where AA and D had good results. Very few tests of C cells. Apparently there is not a lot of love for C cells. It was the Soshine I had chosen.
They are out of D cells.
Picked up 8xC on the sale. Got between 4500 > 4900mAh on one capacity test cycle using a mix of Opus, Lii-500, and Zanflare C4. Seem to improve a tad on a 2nd cycle, but not a huge amount.
All came charged from ~1-1.2v. No duds. Longevity untested.
FWIW my Tenergy Centura C (4000) are down to ~ 3400-3900 after 2 years of fairly constant use.
Has anyone tried dismantling RC NiMH battery packs that have C size cells?
I bet they’re pretty robust discharge wise.
