I’m looking to buy a couple lights for my vehicles. My requirements are that the light is built well, has ZERO parasitic drain (preferably a twisty light, as they’re more reliable), runs on either 1xAA or 2xAA, as I’m going to use L91 Lithium primaries.
I prefer a few modes, but it doesn’t have to have a ton of modes or any disco modes. It also doesn’t have to be insanely bright on high either. Anything north of 250 lumens on high works for me, and I would like the low mode to have good runtime in case of a true emergency.
ZL state that the parasitic drain is neglible compared to the self-discharge of the battery. But they also mention that the tailcap can be unscrewed slightly to disconnect the battery so that there’s no parasitic drain.
Jetbeam Jet 1 MK - runs on AA and 14500, twisty.
Lumintop Tool AA - same thing. Tail switch or twisty.
Both are “mechanical”, reliable and quite bright.
Eagtac D25A has a clicky. My older model has three modes including moon, or just one if head is tightened. Blinkies are there, but somewhat hidden. Should there be a need for a beacon to warn others, it’s there. Takes NiMH.
Maglite 2C ML25. Twisty with a low mode on the 192 lumen version and a ton of throw. Get a couple of eneloop spacers (or make some yourself) to run energizer AA L91 lithiums. About as good as it gets for a light running on AA’s for beam pattern and throw.
The ML25 is fatter than a typical 2AA light but not much if any longer – still fits in a glove box or a console. The chunkier size makes it easier to find and provides a better grip that makes it easier to twist on/off with one hand.
The real edge that the ML25 has is it’s reflector that gives it’s throw for distance and a huge spill beam for up close. Great light.
I don’t really understand this. You just need to unscrew the tail cap a little bit when in storage. There will be no parasitic drain. Plus choose mechanical switch over e-switch. Any AA or 2xAA should be fine.
There is one I’d recommend. Sofirn Sp10S. Runs on AA/14500 and will do 310lm on high with Nimh. It IS an e switch, but the parasitic drain is low, 0.14mA as I measured. If that bothers you, unscrew the tail cap 1/8 turn and you’re good. It’s around $18 on Amazon or $14 direct from Sofirn (China). I bought it for the led which is amazing.
Both are great lights. The SP10S being an e-switch will have some parasitic drain - though you could physically lock it out by untwisting the tailcap a hair, eliminating any drain. The Tool will have no parasitic drain - it would probably be my choice for a car.
The Tools with the lighted caps have as much as 3mA parasitic drain. I think both the Sofirn and Tool are great. I like the Sofirn because of the led alone.
Tool AA black. Going for like 17 US dollars right now, no drain at all if you get the non-lit switch, four good modes. IMO it’s a no-brainer, I love mine to bits.
Thanks bud! I just picked one up. They would only let me use the 10% off coupon on one of them, which was kinda annoying. But it’s a really good deal either way!
I have the Tool 2 with both tail switch and flat magnetic tail cap which i use. That makes it a very compact 14500 twisty, and one of the brightest BTW. Very good light.
I could do without the magnet though.
I’ll have to have the Ti version… but it only comes with the tail switch if i’m right.
