Not sure if this is the right place to ask since I’ve only seen one other thread 3 years ago.
I always thought red light therapy was total BS, but after seeing some modern research I’m convinced it could be helpful. However, a lot of the panels out there are really expensive and seem unnecessarily so.
There are companies like MitoRed, Hooga, etc charging $200-$3000 for panels. Generally newer/better ones try to cover a few different frequencies.
Has anyone researched this thoroughly? Found good cheap aliexpress options? I’ve found some cheaper tabletop panels on sale with black friday for $200ish, but to get the multi-frequencies you need to spend a lore more like this panel:
the difference is 850 is invisible and penetrates deeper
660 is visible,
all the wavelengths have benefits, but imo even 660nm by itself has value.
my experience is only w 660nm single LED lights. I use this inexpensive WK03 modded to 660nm on the 100 lumen setting, to soothe sore muscles, moving it over my skin, in direct contact. 660nm is at the top end of the visible range.
There is no sensation of heat from this frequency and intensity, which reassures me that it is thermally safe in direct contact with my body.
I have not researched panels… I imagine they are also effective. I have not leared how to measure red light power levels, and how that guides choosing effective panel distances.
Also have not learned whether some panels are also serving as an IR Heat source.
All your need is red light, so I don’t think the panel form factor actually matters, and a simple flashlight would do. For wider coverage, just slap a piece of paper to diffuse. Panels, on the other hand, don’t have the option of achieving the level of intensity that a flashlight can.
Convoy has plenty of options using the SST20-DR, which is a 660nm emitter. They also sell IR emitters and lights with them. To get a mix of frequencies, it is probable that simply getting 2-3 lights and taping them together makes a cheaper and more powerful option than getting one of those dedicated panels. Certainly way under $100.
While there does exist plenty of evidence for red light therapy, I doubt that this specific distribution has any statistically or practically significant advantage over just, say, 660nm, 850nm, and 630nm, all readily available. I bet simply changing the intensity or duration of exposure makes a bigger difference.
Also, the material/design cost of those panels is way, way less than hundreds of dollars, by 1 or 2 orders of magnitude. The emitters are cheaply available, and so are their drivers, batteries, and optical elements. So I would be suspicious of sellers with such jacked-up prices. In the flashlight world, price-to-value ratio tends to correlate inversely with quality, and more generally, marketers feel no hesitation turning legitimate science into crankery.
As an update if anyone is researching this I am currently testing out this LED panel. I picked it because it is the supplier for MitoPro which is a pretty well regarded red light provider that rebrands it.
Old Sky David therapy light. Different gems inside the clear lexan tip. The DC box has a wide range of adjustments that I have no idea what it does. A buddy passed away and it became mine. Still works despite the grey tape. Do not know what type of light is peering through the gems but it’s fairly bright.
Thanks for posting. I’m in the head scratching stage of learning about this. Would you mind saying How exactly you use it? Like the lady in the pics, simply sit in front of each day for a while? Would a red light only session at my desk each day make sense, or do I really need to get my whole body down in the light (rather than face and chest at the desk… - 2) Do you use the full range of wavelengths this offers? — Thanks a bunch. I know this forum for flashlights and had that trustworthy vibe when my google lead me in here to your post.
I got one of these (actually an earlier model, I have had mine for a couple of years) https://shorturl.at/D2Jax
I have used it on my knees and neck and it seems to help.
There is dosing recommendations out there.
I also have a red laser that I used… mostly 680 nm light. But I can only use it for a few seconds to get the recommended dose… It will burn hairs if left on too long. Maybe not the best option…
I also have modded some flashlights with either 650 or 850 nm leds and used those to good effect by alternating them.
The panel linked is just more convenient and it has a 20 minute timer on it. Plus with the flashlights there is lots of repositioning required. The panel …obviously cover much more area.
I have a skiing buddy that might appreciate that.. he went to the doctor because his knees hurt.. the doctor said he has a condition called O-L-D (no kidding)
I have been using a single 660nm red in a modded light for sore muscles after skiing.. it seems to relieve pain and speed recovery.. but I like the pad you linked better.. more LED, wider coverage, and a timer.. all good things..
I use my light at an output that does not create any heating sensation.. I figure Hot is bad, so I dont use it at max output.. the light is a Wurkkos Wk03. I use the medium mode, which is 100 lumens with the stock 519a 5000K.. after changing to 660nm SST-20, the output reads 60 lumens.. I hold it directly against my body.. it only gets very slightly warm, never hot.
I’ve got one of these but I’ve been a bit hesitant to use it- what sort of risks are their for eye damage? Using it on upper limbs it’s not always easy to avoid looking at it.
I shine a 60 lumen red light at my face every morning. From arms length distance, with my eyelids closed. I can still see the red light, but it is not very bright.
