Hello at all.
My Name is Ralf. In advance sorry for bad english.
I have a problem with 2 Cree-Led’s for Motorcycle.
I surfed and searched around google and the web but cant find the led-driver board thats build in my 2 lamps.
I want to remove the Strobe-Mode.
All over I can read about a “U2 Chip”. But on my board there is no “U2 Chip”. I cant find a similar Layout like my board…
Anybody a solution for me to remove the Strobe-Mode?
This IC does not have built in modes like some LED drivers, they would have to be generated with a MCU by PWM, that is why some might talk about an U2.
I have the same set. The MOSFET acts as a switch for the modes. Easy solution is to solder a bridge from the drain(either middle pin or top base near to inductor) & source(pin closest to the D2070 on board) together. This gives you the bright mode all the time.
Yeah, I was gonna suggest poking each pin of U1 with a meter while the thing was strobing, and see which pin was also “strobing” in time with it. That’s likely the output-pin that’s driving the FET. Kinda like bridging always-on the pin (6?) of the ATTiny which drives the 7135s in a regular driver board.
This if you have a tool to measure voltage fluctuations.
If not, try shorting C2. If that doesn't remove the blinkies, try un-shorting C2 and then shorting C3. One of those probably helps measure "Off time". Bypassed by a short will behave like lots of time elapsed between on-off clicks.
A picture from an angle to help reveal the traces (electrical paths under the solder resist coating) might help us help you.
I've solved the problem with a 1K resistor adding parallel at the big cap which keep the memory alive. you can add a higher resistor (say 4K7) so you can keep the original function if you switch within 15 seconds.
Good day, I have the same problem, i think i am using a Copy version of Cree U5, i saw a different board, hope somebody can help me remove the low and strobe fun!
